When I run "#show sip-ua calls" command, it shows
"Negotiated Codec : g711ulaw (160 bytes)",
as mentioned here http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_s08_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1370370
But when I checked it in wikipedia for g711ulaw it is 64 Kbps (wiki : G.711 is a narrowband audio codec that provides toll-quality audio at 64 kbit/s.). 160 bytes is nowhere related to 64 Kb.
What is the actual bandwidth used in this case for this call?
-Pandi
Solved! Go to Solution.
The bit rate is 64Kbps, the voice payload is 160 Bytes.
See http://www.cisco.com/c/en/us/support/docs/voice/voice-quality/7934-bwidth-consume.html
Hailey
Hailey
Thanks David, this helps me a lot.
So according to the link you have given, for one call it uses 11.2 kbps right?
That depends on L2 and L3 headers
