Does MMoIP to VoIP work?
Using a SMTP request and the following TCL script: app_voicemail_offramp.2.0.0.0.tcl I'm able to generate a call.
We have a Cisco 3825 and a Cisco 3925. The first one uses a SIP trunk and the latter uses ISDN. The 3825 obviously uses a VoIP dialpeer. My question is: does MMoIP to VoIP work? Because the configurations in both the Ciscos are the same except for the dialpeers. On the 3825 I cant get a call to be generated.
application
  service offramp flash:app_voicemail_offramp.2.0.0.0.tcl
     param mail-script playSound
dial-peer voice 4002 mmoip
service offramp
incoming called-number ..........
dial-peer voice 1000 pots
description Outgoing ISDN
destination-pattern 0T
port 0/3/0:15
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
No.
T.37 to SIP trunk is not supported. The reason is that there is no DSP involved to make a fax call.
paolo bevilacqua
Hall of Fame Master
No.
Alright, thank you.
Recognize Your Peers
