Does MMoIP to VoIP work?
Using a SMTP request and the following TCL script: app_voicemail_offramp.2.0.0.0.tcl I'm able to generate a call.
We have a Cisco 3825 and a Cisco 3925. The first one uses a SIP trunk and the latter uses ISDN. The 3825 obviously uses a VoIP dialpeer. My question is: does MMoIP to VoIP work? Because the configurations in both the Ciscos are the same except for the dialpeers. On the 3825 I cant get a call to be generated.
application
  service offramp flash:app_voicemail_offramp.2.0.0.0.tcl
     param mail-script playSound
dial-peer voice 4002 mmoip
service offramp
incoming called-number ..........
dial-peer voice 1000 pots
description Outgoing ISDN
destination-pattern 0T
port 0/3/0:15
paolo bevilacqua
No.
T.37 to SIP trunk is not supported. The reason is that there is no DSP involved to make a fax call.
paolo bevilacqua
No.
Alright, thank you.
