02-02-2017 09:37 AM - last edited on 03-25-2019 08:41 PM by ciscomoderator
Does anyone knows If the Cisco 3925 Supports a VIC3-4FXS/DID and a VIC2-4FXO without the SM-NM-ADPTR adapter?
Solved! Go to Solution.
02-02-2017 04:16 PM
You do not need any adapter for these cars, see compatibility:
http://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
In fact the SM-NM-ADPTR is for PVDM2 chips to be insertable into 29/39XX routers and not for any voice cards.
If your question was about wether you require PVDMs then the answer is absolutely, you should get PVDM3 for any TDM based cards.
02-02-2017 04:16 PM
02-03-2017 06:40 AM
Chris,
Thanks again for your time. Appreciated.
Cesar Fiestas
