Does UC Locale Installer 8.6.2.1000-1 support CUCM release 8.6(2a)SU2 ?
MehmetKaya
Hi All,
My aim is using  cm-loaclee-tr_TR-8.6.2.1000-1.sgn TRK with Cisco UC 8.6(2a)SU2. I have read the UC locale installer readme file. There is written it works with Cisco UC 8.6.
I want to verify that, does UC Locale 8.6.2.1000-1( Turkish work with Cisco UCM 8.6(2a)SU2 ?
Cisco UC version detail: 8.6.2.22900-9
Locale Installer detail:  TR-8.6.2.1000-1.
http://www.cisco.com/web/software/282074333/56046/cm-locale-8.6.2.1000_ReadMe.txt
It should..!!
Thanks for your quick responce . I hope it should works but ı need to verify that issue before upgrading.
MehmetKaya
is there anyone would try it ?
Sent from Cisco Technical Support Android App
