Does User can change the pin number
gssnettech
Beginner
Beginner
Hi All
I have a question, our customer has two ccms and one unity connection , the user using EM login their ccm to get extension number. the end user account synchronize from ad server. customer hope that the user can change pin number by themselves.
Does any can help me !!! thanks a lot
Jaime Valencia
Users can change their PIN via CCMUser or if you use 8.X and above also from phone.
Extension Mobility Change PIN
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/phones.html#wp1483628
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
