07-13-2017 06:23 AM - edited 03-17-2019 10:46 AM
Hi everyone,
Does anyone know if vCUBE supports SRST mode (i.e. fallback if all servers in the CM Group are down)?
If so, is it under the same licensing constraints as vCUBE as a sip server (APPx licensing or above)?
Thanks!
Solved! Go to Solution.
07-13-2017 06:35 AM
Hi Nadav,
You cannot have SIP SRST as of now, on cisco CUBE gateway.
But you can expect something at end of November this year
(Rate if it helps)
JB
05-28-2018 06:07 AM
07-13-2017 06:35 AM
Hi Nadav,
(Rate if it helps)
JB
07-13-2017 01:15 PM
Thanks, good to know it's on the roadmap.
04-26-2018 09:25 AM
05-28-2018 05:09 AM
Hi everyone,
Any news regarding a virtual SRST instance in the near future?
05-28-2018 06:07 AM
