Domain name change.
maurito_romero
My company is changing its internal active directory domain name, and CUCM 8.5, CUPS 8.5, CCX 8.5 and CUC 8.5 are using DNS to resolve names.
I have to change this applications from using DNS to use IP adress or the new DNS domain name.
What is the procedure from changing this apps??
I have never carried out the tasks you are attempting but I have gleened some additional info
From this link - you need to use CLI
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_5_1/cli_ref_851.html#wp40005
set network domain NEW.COMP.COM
Before entering any of this I would check witrh TAC if your stepped plan of actions is suitable.
Alex
Regards, Alex. Please rate useful posts.
5 Replies 5
acampbell
Have a look at this link
I am sure you will find what you need to do here:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/ipchange/ipchg851.html
Alex
Hi acampbell, thanks for your answer. I've already seen this document but it doesn't say anything about a domain name change, just how to change the ip address or the hostname, my question is how to change from ccm01.mycompany.com to ccm01.mynewinternaldomain.com.
Alex
I will open a Case with TAC and put the procedure here.
acampbell, I changed the domain name entering set network domain newdomain.com then rebooted the publisher and the subscriber server and it works.
Thanks for your help!.
