Dos CME 9.0 suports SIP phones?
hector.aguirre
             Hi communty,
Please Help me whit this information:
Dos CME 9.0 suports SIP phones? Cisco phones only? Whic references?
3 Accepted Solutions
Chris Deren
Yes, any Cisco phones that support SIP can be ran as SIP phones on CME.
Chris
ronpatel
Level 8
Level 8
HI
See below link , It shows all the supported SIP firmware for SIPp phone.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
paolo bevilacqua
I suppose you want to know about non-cisco phones, because using Cisco phone with SIP firmware is not a good idea (loose features but gain bugs and limitations).
The answer is that Cisco does not officialy support third-party SIP phones on CME, however Cisco requires  a license if you want to use them!
  • CallManager Express UL For Single Line 3rd Party SIP Phones
  • CallManager Express UL For Multi Line 3rd Party SIP Phone
Because of that, and technical reasons also, is better to avoid them as much as possible.
7 Replies 7
Chris Deren
Chris
Thank you Mr Deren!
ronpatel
Level 8
Level 8
HI
Ronak patel
Rate helpful posts.
Thank you Sr.
paolo bevilacqua
Thank you MR Paolo
You're welcome, thank you for the nice rating and good luck!
