04-19-2018 11:34 AM - edited 03-17-2019 12:39 PM
Hi Guys,
My Customer have the solution with CUCM 10.5.2 and 06 sites running SIP protocol. The Customer changed the protocol, previouly were H.323 and now it running SIP with change range Phone number. In any sites the Caller ID that is appearing is the old number. The Carrier informed that forward the number that my network send for They. My question is: Where I see in the gateway what number is send for the Carrier.
Wilson
04-19-2018 12:42 PM
debug ccsip messages will show you the signaling exchange between CUCM and your router, and your router and the carrier.
You mention that you have changed phone numbers with the change in carrier. Did you reconfigure the External Phone Number Mask on the Phone-Dn for your users? (And/Or transformation patterns if you are doing Globalized Call Routing?)
04-20-2018 04:54 AM
Hi Marren,
Thanks a lot for Your contact. Unfortunatelly my profile not allow run debug.
About External Phone Number Mask are blank for all extensions.
About transformation patterns if you are doing Globalized Call Routing. The answer is yes
Thank You,
Wilson
04-20-2018 07:23 AM
OK. Since you are doing Globalized Call Routing, have the transformation patterns used by the SIP Trunk been adjusted to reflect the new DIDs with the new carrier?
These would be the Calling Party Transformation patterns indicated in the Outbound Call Routing section of your SIP Trunk. On the trunk, look at Outbound Cal Routing > Calling Party Transformation CSS. Backtrack and figure out which set of transformation patterns are in that CSS. Are they set to the new DNs?
And, yes, please also post the config of your router. It may be that the router is doing the old-numbering digit manipulation.
04-19-2018 06:56 PM
You might be able to use debug isdn q931
Add a debug condition to limit the output if you use it
Something like:
voicegate# term mon
voicegate# debug condition called 7895551212
voicegate# debug isdn q931
after the capture:
voicegate# term no mon
voicegate# u all
The called number can be your cell phone.
You can also look at RTMT logs and CDR from CM, but instant information will come from the debug.
The debug ccsip messages will work even better if you don't have a trunk to the PSTN.
Here is a Cisco Command Reference guide for SIP debug conditions and output filtering:
04-20-2018 04:58 AM
Hi Jaca,
Thanks a lot for Your contact. Unfortunatelly my profile don´t have permission to run debug.
About RTMT what logs that I set will show this?
Very usual the link that You send. Thank You
Wilson
04-20-2018 05:16 AM
Once you have RTMT up and running go to:
Voice/Video || Session Trace Log View || Real Time Data
Add the number called and the date and time.
I see from your other posts you have no CLID set within CM. You may have a translation within the gateway sending outbound, but with no running configuration I'm just guessing.
04-20-2018 05:44 AM
Hi Jaca,
About RTMT that You mentioned: Voice/Video || Session Trace Log View || Real Time Data, it show the calling number - originate number, but, the when called receive that the calling number show is different.
About translation between CUCM and Gateway, in the CUCM there are not this translation. As I see in the gateway?
Wilson
04-20-2018 06:01 AM
Post the configuration of the gateway that holds the trunk in question please.
04-20-2018 09:33 AM
04-20-2018 12:31 PM
Hi Nipun,
Thanks a lot for Your contact. Follow the gateway config
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.04.20 16:11:34 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 14688 bytes
! Last configuration change at 19:00:54 GMT Thu Apr 19 2018 by us_bdavidson
version 15.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname XPTO_BR500_VGW
boot-start-marker
boot system flash c2951-universalk9-mz.SPA.154-3.M5.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
logging queue-limit 10000
logging buffered 10000000
logging rate-limit 10000
enable secret 5 $1$0/Aw$7X8JB2hhHEqmtI/UcdUNW.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default local
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
clock timezone GMT -3 0
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name XPTO.com
ip cef
no ipv6 cef
trunk group PSTN
hunt-scheme round-robin both up
translation-profile incoming PSTN-IN
translation-profile outgoing PSTN-OUT
cts logging verbose
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service pots
fax rate disable
voice service voip
ip address trusted list
ipv4 192.168.104.2
ipv4 192.168.104.1
ipv4 10.64.0.8
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
session transport tcp
min-se 2400 session-expires 2400
registrar server expires max 600 min 60
asserted-id pai
midcall-signaling passthru
g729 annexb-all
sip-profiles 1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class sip-profiles 1
request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
request REINVITE sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
voice class e164-pattern-map 1
description CARRIER - BR500 DID Ranges
e164 +337338344704
e164 +6622723095..
e164 +6622424285[0-4].
e164 +6622681697[4-9].
voice class e164-pattern-map 2
description CARRIER - BRA DID Ranges
e164 723095..
e164 681697[4-9].
e164 85[0-4].
e164 95..
e164 97[4-9].
voice register global
mode srst
timeouts interdigit 5
system message WAN Outage - Fallback Mode
max-pool 250
voice register pool 1
translation-profile incoming SRST-IN
id network 10.0.0.0 mask 233.0.0.0
dtmf-relay rtp-nte sip-notify
voice-class codec 1
no vad
voice translation-rule 10
rule 1 /^\([2-5].......\)$/ /+6622\1/
rule 2 /^\([79][6-9].......\)$/ /+6622\1/
rule 3 /^\([1-9][1-9][2-9].......\)$/ /+33\1/
rule 4 /^\([1-37-9][1-9][79]........\)$/ /+33\1/
rule 5 /^\00\(.*\)$/ /+\1/
rule 6 /^\(.*\)$/ /+\1/
voice translation-rule 20
rule 1 /^\(97..\)$/ /+66226816\1/
rule 2 /^\(8...\)$/ /+66224242\1/
rule 3 /^\(68169...\)$/ /+6622\1/
rule 4 /^\(95..\)$/ /+66227230\1/
rule 5 /^\(723095..\)$/ /+6622\1/
voice translation-rule 30
rule 2 /.*/ /8500/
rule 3 /^\+.*/ /8500/
voice translation-rule 40
rule 2 /^0\([2-9].......\)$/ /\1/
rule 3 /^0\([79]........\)$/ /\1/
rule 4 /^0\(19.\)$/ /\1/
rule 5 /^0\(181\)$/ /\1/
rule 6 /^0\(911\)$/ /\1/
rule 7 /^0\(112\)$/ /\1/
rule 8 /^00\([1-9][1-9][2-9].......\)$/ /076\1/
rule 9 /^00\([1-9][1-9][2-9]........\)$/ /076\1/
rule 10 /^00\([4-6][1-9]9[6-9].......\)$/ /076\1/
rule 11 /^00\([1-37-9][1-9][79]........\)$/ /076\1/
rule 12 /^00\([38]00.......\)$/ /0\1/
rule 13 /^000\([1-9].*\)$/ /0076\1/
rule 14 /^0\(.*\)$/ /\1/
voice translation-rule 50
rule 1 /^\(97[4-9].\)$/ /+66226816\1/
rule 2 /^\(329.\)$/ /+33335284\1/
rule 3 /^\(8[78]..\)$/ /+33338526\1/
rule 4 /^0$/ /+662268169740/
voice translation-rule 60
rule 11 /^\+6622\([2-9].......\)/ /0\1/
rule 12 /^\+6622\([79]........\)/ /0\1/
rule 13 /^\+33\([1-9][1-9][2-9].......\)/ /00\1/
rule 14 /^\+33\([1-37-9][1-9][79]........\)/ /00\1/
rule 15 /^\+\([1-9].*\)/ /000\1/
voice translation-profile NOPLUS-IN
translate called 60
voice translation-profile PSTN-IN
translate calling 10
translate called 20
voice translation-profile PSTN-OUT
translate calling 30
translate called 40
voice translation-profile SRST-IN
translate called 50
license udi pid CISCO2951/K9 sn FJC2020A0PU
license accept end user agreement
license boot module c2951 technology-package uck9
hw-module pvdm 0/0
hw-module sm 1
username cbnetsvc password 7 08707D6F334B12040A
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description UPLINK TO DMZ-SW
ip address 10.46.30.5 233.233.233.0
duplex auto
speed auto
interface GigabitEthernet0/1
description UPLINK TO SIP SERVICE
ip address 10.74.3.250 233.233.233.252
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.46.30.1
ip route 176.16.0.102 233.233.233.233 10.24.3.249
ip route 10.24.3.249 233.233.233.233 GigabitEthernet0/1
ip tacacs source-interface GigabitEthernet0/0
ip ssh time-out 60
ip ssh version 2
ip access-list standard SNMP_SERVERS
permit 176.17.240.170
permit 176.15.18.16
permit 176.17.104.5
permit 176.15.18.17
permit 176.15.18.15
permit 176.17.241.197
permit 176.17.223.27
permit 176.17.226.14
permit 176.17.240.8
permit 176.17.240.76
permit 176.17.241.68
permit 176.17.241.67
permit 176.17.198.80 0.0.0.15
deny any log
ip access-list extended BOX
permit ip any 45.58.64.0 0.0.15.233
permit ip 45.58.64.0 0.0.15.233 any
ip access-list extended DROPBOX
permit ip any 72.21.80.0 0.0.15.233
permit ip 72.21.80.0 0.0.15.233 any
ip access-list extended PCAP_ACL
permit ip any any
ip access-list extended WIRELESS-DATA
permit udp any any eq 5247
permit udp any eq 5247 any
logging trap notifications
logging source-interface GigabitEthernet0/0
logging host 176.17.206.60
logging host 176.17.105.85
nls resp-timeout 1
cpd cr-id 1
snmp-server community h0tsauce RO SNMP_SERVERS
snmp-server community gr33n RO SNMP_SERVERS
snmp-server community ch1ll1 RW SNMP_SERVERS
snmp-server ifindex persist
snmp-server location XPTO, Brazil
snmp-server system-shutdown
snmp-server enable traps tty
snmp-server enable traps syslog
tacacs-server host 176.17.198.120
tacacs-server host 176.15.18.13
tacacs-server directed-request
tacacs-server key 7 111D1A061E1406
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.104.1 identifier 2 version 7.0
sccp ccm 192.168.104.2 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register BRA_BR500_CFB
associate profile 2 register BRA_BR500_XCODE
associate profile 3 register BR500_711U_MTP
associate profile 4 register BR500_711A_MTP
associate profile 5 register BR500_729R8_MTP
keepalive retries 5
switchover method immediate
switchback method immediate
switchback interval 15
dspfarm profile 2 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 26
associate application SCCP
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 28
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 100
dspfarm profile 4 mtp
codec g711alaw
dspfarm profile 5 mtp
codec g729r8
dial-peer voice 150 voip
preference 1
session protocol sipv2
session target ipv4:192.168.104.2
destination e164-pattern-map 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
fax protocol pass-through g711ulaw
no vad
dial-peer voice 250 voip
preference 2
session target ipv4:192.168.104.1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 9911 voip
description Outbound calls to PSTN
preference 1
destination-pattern 0911$
session target ipv4:176.16.0.102
incoming called e164-pattern-map 2
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 100 pots
tone ringback alert-no-PI
description Inbound calls from PSTN
incoming called-number .
direct-inward-dial
dial-peer voice 9112 voip
preference 1
destination-pattern 0112$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 9192 voip
preference 1
destination-pattern 019.$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 9181 voip
preference 1
destination-pattern 0181$
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1000 voip
description Outbound calls from UCM
translation-profile incoming NOPLUS-IN
incoming calling e164-pattern-map 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 110 voip
destination-pattern 0T
session transport udp
voice-class codec 1
voice-class sip early-offer forced
voice-class sip profiles 1
voice-class sip profiles 1 inbound
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 1001 voip
description Inbound calls from CARRIER
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
retry invite 2
timers trying 300
g729-annexb override
gatekeeper
shutdown
call-manager-fallback
max-conferences 16 gain -6
transfer-system full-consult
ip source-address 10.96.30.5 port 2000
max-ephones 75
max-dn 150 dual-line
system message primary WAN Outage - Fallback Mode
XPTO_BR500_VGW#
XPTO_BR500_VGW#
XPTO_BR500_VGW#
04-20-2018 12:39 PM
You have translation profiles on your dial peers.
You may want to do a show voice call stat to see what your in/out dial peers are and check them against these dial peers:
Which all have your xlate profile outgoing hitting rule 30 and 40
From your config and without knowing your dialed number this would be a good starting point:
trunk group PSTN
translate called 40
rule 2 /.*/ /8500/
On these dial peers:
04-20-2018 12:42 PM
You can also test your translation rule like such,
test voice translation rule 40 7408881212
and you'll get something back like:
pbx-router#test voice translation-rule 40 7408881212
Matched with rule 12
Original number: 2694003 Translated number: 0117408881212
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
Here's Cisco documentation on testing voice translation rules:
04-26-2018 06:15 AM
Hi Jaca,
Sorry by long delay in answer. Unfortunatelly my profile don´t privilegius to run the command: test voice-translation-rule x
Wilson
