Doubt about caller ID
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a solution with CUCM 10.5.2 using SIP Protocols. The main number (example) is 5432-1000 and many DNs 1001, 1002,.....,10XX. Independent of number used to dial to external number example: 5432-1075 dialing to 98765432  the call go as 5432-1000. As to configure CUCM to that the calls go with the original number? A read the documentation about Caller ID, but, didn´t clear for me.
Can You help me, please.
Wilson
2 Accepted Solutions
R0g22
If you have a per user DID in your environment, you can configure EPNM for your Phone lines. Your route patterns/TP can then use this EPNM to send the ANI/CLID correctly.
http://www.ciscopress.com/articles/article.asp?p=1745737&seqNum=2
It all depends on your dialplan implementation and where you do your digit
manipulation. For example if all manipulations are done on route-patterns
then in your calling number translation put this 5432XXXX
Do the same thing if you decide on put your manipulations on translation
pattern or sip trunk calling pattern transformation.
R0g22
