02-09-2009 08:51 AM - edited 03-15-2019 04:04 PM
Hi Guys,
My Customer is using CCM version 5.1 and have the following doubt: It's possibility configure CDR to show that FAC or there are any field in CDR that show the FAC?
Wilson Santana
02-09-2009 09:20 AM
CAR already has FAC and CMC reports
java
if this helps, please rate
02-09-2009 10:28 AM
Hi Javalenc,]
I am sorry, but, the CDR don't have this feature?
Wilson Santana
02-09-2009 10:32 AM
let's clear something out.
CDR and CAR were different DBs in windows versions.
in linux versions there is only one DB, CAR.
there is no separate CDR database, you can get the info from the DB or use an external billing application for CDRs to process the flat files
java
02-09-2009 10:38 AM
Hi Javalenc,
In this case my Customer will need configure the CAR to can see the FAC? Because, He work version 5.1 (linux)
Wilson Santana
02-09-2009 10:48 AM
yes, or as i mentioned configure a 3rd party billing server
java
02-10-2009 09:08 AM
Hi Javalenc,
It's possible inform to me in which field in the CAR I can found the FAC?
Wilson Santana
02-17-2009 11:48 AM
