07-03-2018 05:32 AM - edited 03-18-2019 12:27 PM
Hi Guys,
I don´t have experience with implementation about CUCME and would like know as work the license process. My Customer will put CUCME in the remotes sites and in general each sites have in medium 50 Users. Currently in the Gateways with configuration SIP and CUBE in the same gateways. 05 sites have Gateway 29xx and 01 site have the ISR 4351.
Is need bought license to CUCME and Devices, correct?
Could You help me?
Wilson
07-03-2018 06:14 AM
typically you buy the bundle wchich contains 25 license for cme:
C2911-CME-SRST/K9 bundle includes FL-CME-SRST-25 so you would need to buy additional ones
07-03-2018 08:14 AM
Hi Dennis Mink,
Thanks a lot for Your contact. One doubt: I verified with command "show inventory" and didn´t appear this information. This information should be with this command or there are another?
Wilson
07-03-2018 06:24 AM
07-03-2018 06:41 AM
07-03-2018 08:19 AM
Hi Nipun,
Thanks a lot for Your contact and explanation. One doubt: Is possible have in the same equipment about SIP and CUBE configured and the same time CME too? My Gateways models are: 2901, 2921, 2951 and ISR 4351
Wilson
07-03-2018 08:51 AM
07-04-2018 08:52 AM
Hi Nipun,
One doubt with gateway 4351 is possible configure all (Cube, SIP and CME)? Today the gateway is configured with Cube and SIP.
Wilson
07-04-2018 08:54 AM
07-03-2018 08:16 AM
Hi Prashant,
Thanks a lot for Your contact and explanation. I verified in the gateway and there are not the command "show license summary"
Wilson
