dowload attendant console - CUBAC
ciscoroyzhang
Hi all
try to download the CUBAC but the file availbe is  ova file format and file size is only 0.13MB not exe file. so I guess this is not the right one.
try the CUACCEinstall.exe compact edition, comes with exe format, can some one advice what is difference between the compact edition and the CUBAC?
thanks in advance.
Roy
acampbell
This software is downloaded from a different website than normal.
http://cisco-ac.arcsolutions.com/UserWebSite/cisco/ciscodefault.aspx
Please look at the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUBAC_WA_861main.pdf
Go to appendix E
This gives the information as to how to obtain and license the CUBAC software
Alex
Regards, Alex. Please rate useful posts.
jamgale
Level 3
Level 3
Hi Roy,
You can download the software from www.cisco.com/go/ac, this does infact redirect you to the site mentioned in Alex's post but this one is easier to remember :-)
The OVA you have is only the minimum settings for a VM image, so it contains data such as how much RAM to use, HDD size, CPU etc.
Compact Edition is a console which is compatible with the CUCM Business Edition 3000 platform only, it cannot be used against a Business Editon 6000 or a Classic CUCM.
thanks guys for detailed explaination, much appreciated. cheers
