4126
Highlighted
Download License file from Enterprise License Manager (CUCM 9.1)
Dear Experts,
I need to download the License file from CUCM 9.1.
Kindly advise how to get the license file (bin file)
Thanks in advance
Anas
1 ACCEPTED SOLUTION
Highlighted
Hi Anas,
you can try using command license file get  from OS administration using putty.
admin:license file get
Number of files: 13
Total size in Bytes: 85016
Total size in Kbytes: 83.02344
Would you like to proceed [y/n]? y
SFTP server IP: 192.168.1.1
SFTP server port [Default = 22]:
User ID: test
Password: ****
Download directory: /
Connecting to remote server: 192.168.1.1
The authenticity of host '192.168.1.1 (192.168.1.1)' can't be established.
RSA key fingerprint is af:06:b2:cc:e3:76:b5:44:d3:7f:48:81:33:26:20:b5.
Are you sure you want to continue connecting (yes/no)? yes
Sending to remote server: 192.168.1.1
Transfer complete
192.168.1.1 is IP address of PC on which sftp is running.
the files would get stored in a folder in name of IP address of  PUBlisher  followed by date/time---->license files.tar--->common---> elm --->data ---->licResponse folder .in this, u can get .bin files.
I think u would get same in CUCM9 .
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/9_0_1/CUCM_BK_C3A58B83_00_cucm-cli-reference-guide-90/CUCM_BK_C3A58B83_00_cucm-cli-reference-guide-90_chapter_0100.html
regds,
aman
15 REPLIES 15
Highlighted
Anas,
Refer to below links:
https://supportforums.cisco.com/document/12366606/elmplm-obtaining-license-request-and-uploading-license-files
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/elmuserguide/9_0_1/CUCM_BK_E596FD72_00_enterprise-license-manager-user-90/CUCM_BK_E596FD72_00_enterprise-license-manager-user-90_chapter_011.html#CUCM_TK_GB7568CA_00
Deepak
- Rate Helpful Posts -
Highlighted
Hi Anas,
Number of files: 13
User ID: test
Password: ****
Transfer complete
regds,
aman
Highlighted
Hi Aman,
Thanks for your reply.
Unfortunately this command "license file get" is not showing in the ELM
I have only the below option
  • License file client
  • License file diagnose
  • Licnese file management
Do you have any other option ?
Anas
Highlighted
Anas,
Did you check the above mentioned posts
Deepak
Highlighted
Deepak,
I check the above the posts. they are not solving my problem.
Anas
Highlighted
where are you getting stuck which point .What is the issue you are running into. Explain the complete steps you are following there and which one is not working
Are you trying to download the license file that is already uploaded on the ELM server. Is that what you are trying to acheive
Deepak
Highlighted
I am trying to download a license file that is already uploaded on the ELM.
I am facing issue with that. the command line "license file get" is not working.
do you have any other idea ?
Anas
Highlighted
Hi Anas,
this could be the issue
https://supportforums.cisco.com/discussion/12009031/cisco-elm-file
regds,
aman
Highlighted
Hi Aman,
thanks for your reply.
My issue is related to that post, "license file get" is not appearing.
I need this file because cisco licensing team is asking for that.
regards
Anas
Highlighted
Anas,
So what you are saying is that, you do not see "license file get" command at all. Can you simple type ? and see what all commands are there. Example from my lab:
admin:
      delete*
      file*
      help
      license*
      quit
      run*
      set*
      show*
      unset*
      utils*
Also ,can you do show myself and check the privilege level:
admin:show myself
Machine Name : cucm10pub
account name : osadmin
privilege level : 4
command count : disabled
logging setting : disabled
Output of below commands:
show version active
show tech network hosts
show network eth0
Deepak
Highlighted
Hi Anas,
you can involve Cisco TAC so that can have root acess to CUCM and help u to fetch lic files.
regds,
aman
Highlighted
Hi All,
It seems "License file get" command is not available on CUCM 9.1(1). it is available from CUCM 9.1(2) and onward.
I get the license file from the upgraded version of 10.5
Thanks for your help
Anas
Highlighted
What's the point? The license is valid only on the single ELM server you have uploaded it to.
Why do you need it?
If you have the Cisco SO numbers for your orders you can evidence that you own the licenses.
If you have them on your ELM, this proves you own them. Back the server up.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Highlighted
I am upgrading from vesion 9 to version 10.5 with active ucss contract.
I need it because Cisco licensing team is asking for it.
Anas
Content for Community-Ad
