210
Highlighted
Participant
DRS Backing Up Unwanted Files
One of the servers in our CUCM10.5.1.11900-13 cluster died so we had to re-add it.  Everything seems to have gone successfully, except that DRS wants to back up the TFTP service, CEF, and the Directory Number Alias Lookup service even though neither of these services are activated.   Because of this the backup fails.  How can I get DRS to stop trying to back up services that aren't running?
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
I would first start with
I would first start with restarting the DRS services on the nodes and then test.
  • utils service restart drf local
  • utils service restart drf master
If you still get the errors in the backup job, I would restart the tomcat service on the nodes and the test.
  • utils service restart tomcat
If you STILL get errors, I would raise a TAC case (you may need to do a reboot but I would have TAC look at it first).
Ryan
10 REPLIES 10
Highlighted
Enthusiast
Can you log into the cluster
Can you log into the cluster publisher's CLI and provide the output of;
  • utils dbreplication runtimestate
  • utils diagnose module validate_network
After the previous node died, did you also remove it's processNode reference in the cluster (System -> Server) of the Cisco Unified CM Administration web interface) before reinstalling the node back into the cluster?
Ryan
(: ... Please rate helpful posts ... :)
Highlighted
Participant
I cannot post actual names or
I cannot post actual names or IPs of the devices, so I had to change the output a bit.  Suffice to say the host names and the IPs are all correct in the real output.  The server marked CUCM08 is the one we just re-added.   CUCM00 is the publisher.
admin:utils dbreplication runtimestate
Server Time: Mon Jan 11 20:29:18 UTC 2016
Cluster Replication State: BROADCAST SYNC Completed on 14 servers at: 2015-12-24-04-27
     Last Sync Result: SYNC COMPLETED on 680 tables out of 680
     Sync Status: NO ERRORS
     Use CLI to see detail: 'file view activelog cm/trace/dbl/20151224_014550_dbl_repl_output_Broadcast.log'
DB Version: ccm10_5_1_11900_13
Repltimeout set to: 1800s
PROCESS option set to: 1
Cluster Detailed View from XXXXXXCUCM00 (15 Servers):
                                      PING      DB/RPC/   REPL.    Replication    REPLICATION SETUP
SERVER-NAME  IP ADDRESS        (msec)    DbMon?    QUEUE    Group ID       (RTMT) & Details
XXXXXXCUCM12 XX.XX.XX.XX      33.087    Y/Y/Y     0        (g_15)         (2) Setup Completed
XXXXXXCUCM04 XX.XX.XX.XX      0.152     Y/Y/Y     0        (g_6)          (2) Setup Completed
XXXXXXCUCM06 XX.XX.XX.XX      0.240     Y/Y/Y     0        (g_8)          (2) Setup Completed
XXXXXXCUCM05 XX.XX.XX.XX      0.249     Y/Y/Y     0        (g_7)          (2) Setup Completed
XXXXXXCUCM03 XX.XX.XX.XX      0.313     Y/Y/Y     0        (g_5)          (2) Setup Completed
XXXXXXCUCM09 XX.XX.XX.XX      32.581    Y/Y/Y     0        (g_12)         (2) Setup Completed
XXXXXXCUCM01 XX.XX.XX.XX      0.195     Y/Y/Y     0        (g_3)          (2) Setup Completed
XXXXXXCUCM02 XX.XX.XX.XX      0.203     Y/Y/Y     0        (g_4)          (2) Setup Completed
XXXXXXCUCM10 XX.XX.XX.XX      32.521    Y/Y/Y     0        (g_13)         (2) Setup Completed
XXXXXXTFTP01 XX.XX.XX.XX      0.151     Y/Y/Y     0        (g_11)         (2) Setup Completed
XXXXXXTFTP02 XX.XX.XX.XX      32.534    Y/Y/Y     0        (g_16)         (2) Setup Completed
XXXXXXCUCM00 XX.XX.XX.XX      0.021     Y/Y/Y     0        (g_2)          (2) Setup Completed
XXXXXXCUCM07 XX.XX.XX.XX      0.279     Y/Y/Y     0        (g_9)          (2) Setup Completed
XXXXXXCUCM11 XX.XX.XX.43      32.588    Y/Y/Y     0        (g_14)         (2) Setup Completed
XXXXXXCUCM08 XX.XX.XX.38      0.286     Y/Y/Y     0        (g_26)         (2) Setup Completed
admin:file view activelog platform/log/diag3.log
01-11-2016 20:33:18                       Diagnostics Version: 1.0.0
01-11-2016 20:33:18                       getting hardware model [/usr/local/bin/base_scripts/sd_hwdetect HWModel]
01-11-2016 20:33:18                       Hardware Model: VMware
01-11-2016 20:33:18                       getting verson number [rpm -q --nodigest --nosignature master | sed -e "s/master-//"]
01-11-2016 20:33:18                       Version: 10.5.1
01-11-2016 20:33:18 disk_space:           Is valid module: True
01-11-2016 20:33:18 disk_files:           Is valid module: True
01-11-2016 20:33:18 service_manager:      Is valid module: True
01-11-2016 20:33:18 tomcat:               Is valid module: True
01-11-2016 20:33:18 tomcat_deadlocks:     Is valid module: True
01-11-2016 20:33:18 tomcat_keystore:      Is valid module: True
01-11-2016 20:33:18 tomcat_connectors:    Is valid module: True
01-11-2016 20:33:18 tomcat_threads:       Is valid module: True
01-11-2016 20:33:18 tomcat_memory:        Is valid module: True
01-11-2016 20:33:18 tomcat_sessions:      Is valid module: True
01-11-2016 20:33:18 tomcat_heapdump:      Is valid module: True
01-11-2016 20:33:18 validate_network:     Product specific XML file: /usr/local/platform/conf/cli/cliProduct.xml
01-11-2016 20:33:18 validate_network:     val: true
01-11-2016 20:33:18 validate_network:     Is valid module: True
01-11-2016 20:33:18 validate_network_adv: Is valid module: False
01-11-2016 20:33:18 raid:                 getting cpu speed [/usr/local/bin/base_scripts/sd_hwdetect CPUSpeed]
01-11-2016 20:33:18 raid:                 CPU Speed: 2400
01-11-2016 20:33:18 raid:                 model = VMware
01-11-2016 20:33:18 raid:                 Is valid module: True
01-11-2016 20:33:18 system_info:          Is valid module: True
01-11-2016 20:33:18 ntp_reachability:     Is valid module: True
01-11-2016 20:33:18 ntp_clock_drift:      Is valid module: True
01-11-2016 20:33:18 ntp_stratum:          Is valid module: True
01-11-2016 20:33:18 sdl_fragmentation:    Is valid module: True
01-11-2016 20:33:18 sdi_fragmentation:    Is valid module: True
01-11-2016 20:33:18 ipv6_networking:      IPV6INIT=no
01-11-2016 20:33:18 ipv6_networking:      IPv6 initialized: no
01-11-2016 20:33:18 ipv6_networking:      False
01-11-2016 20:33:18 ipv6_networking:      Is valid module: False
01-11-2016 20:33:18
01-11-2016 20:33:18                       --> executing test [validate_network], fix: fixauto, stop on error: False
01-11-2016 20:33:18
01-11-2016 20:33:18 validate_network:     ------------------
01-11-2016 20:33:18 validate_network:     Testing networking, but skipping duplicate IP test.
01-11-2016 20:33:18 validate_network:     checking network [/usr/local/bin/base_scripts/validateNetworking.sh -n]
01-11-2016 20:33:19 validate_network:     retrieving pub name from [/usr/local/platform/conf/platformConfig.xml]
01-11-2016 20:33:19 validate_network:     Hostname: [XXXXXXCUCM00]
01-11-2016 20:33:19 validate_network:     found pub name [XXXXXXCUCM00]
01-11-2016 20:33:19 validate_network:     checking /etc/hosts [grep -q `hostname` /etc/hosts]
01-11-2016 20:33:19 validate_network:     Finding cluster nodes [/usr/local/bin/base_scripts/list_cluster.sh]
01-11-2016 20:33:19 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:20 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:21 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:22 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:23 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:24 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:25 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:26 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:27 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:28 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:29 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:30 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:31 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:32 validate_network:     running [./diag_validate_network_sftp.exp sftpuser@XX.XX.XX.XX>/dev/null]
01-11-2016 20:33:32 validate_network:     does test script exist [/usr/local/bin/base_scripts/networkDiagnostic.sh]
01-11-2016 20:33:32 validate_network:     test script exists
01-11-2016 20:33:32 validate_network:     run network script via expect [./diag_validate_network.exp > /dev/null]
01-11-2016 20:33:33 validate_network:     result: 0, message: Passed
end of the file reached
Highlighted
Enthusiast
Highlighted
Participant
Sorry for not answering that
Sorry for not answering that before.
I'm not the one who did the reinstallation, I was just asked to come in and clean up some issues.  I asked the guy who did the reinstall and he said he did remove it.  Best I can do for you.
Highlighted
Enthusiast
Ryan
Highlighted
Participant
Restarting those services did
Restarting those services did it Ryan.  Thanks.
Highlighted
if you are not runing tftp
if you are not runing tftp server on that sever then it wont take back up for that server.
Highlighted
Participant
That's just the thing Samuel.
That's just the thing Samuel.  The TFTP service is not running on the server, yet it's trying to back up the files for the service.  This server was never a TFTP server, and the service is currently disabled.  When the DRS tries to back it up, there's nothing to back up and the routine fails.
Highlighted
i think you may need to
i think you may need to reboot those server... I would say open a TAC case and let them check it.
Highlighted
Participant
As it turned out I just had
As it turned out I just had to restart the services.  Check out Ryan's response.  Thanks for working with me, though, Samuel.
