01-11-2016 07:32 AM - edited 03-18-2019 11:45 AM
hello,
there is one thing i don't understand regarding the credit system of the DSP. Maybe you can help me.
For a g711 voice call are 15 credits allocated but many other channels uses 23 credits for a voice call. I can't understand where these
23 credits under DSP 1 and 2 come from.
I have looked up the sh voice dsp capabilities but i do not found any entry with these 23 credits.
My second question is if i can see an active conference call with this command or do i see only normal voice calls? I would expect
to see the conference call with 71 credits under dsp 3,4,5 and 6 because of the FLEX_GROUP_CONF. We made some test conferences but do not see these calls under the aforementioned dsp's. Is this normal behaviour or misconfiguration?
sh dsp-group all output:
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 37.3.6
Max signal/voice channel: 43/43
Max credits: 645, Voice credits: 645, Video credits: 0
num_of_sig_chnls_allocated: 43
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 220, reserved credits: 0
Signaling channels allocated: 43
Voice channels allocated: 20
Credits used (rounded-up): 425
Voice channels:
Ch01: voice port: 0/1/0:15.31, codec: g711ulaw, credits allocated: 15
Ch02: voice port: 0/0/1:15.7, codec: g711ulaw, credits allocated: 23
Ch03: voice port: 0/0/1:15.31, codec: g711ulaw, credits allocated: 23
Ch04: voice port: 0/1/1:15.28, codec: g711ulaw, credits allocated: 23
Ch05: voice port: 0/0/0:15.29, codec: g711ulaw, credits allocated: 23
Ch06: voice port: 0/1/1:15.30, codec: g711ulaw, credits allocated: 15
Ch07: voice port: 0/0/1:15.18, codec: g711ulaw, credits allocated: 15
Ch08: voice port: 0/0/1:15.30, codec: g711ulaw, credits allocated: 23
Ch09: voice port: 0/0/1:15.14, codec: g711ulaw, credits allocated: 23
Ch10: voice port: 0/1/0:15.30, codec: g711ulaw, credits allocated: 23
Ch11: voice port: 0/1/0:15.29, codec: g711ulaw, credits allocated: 23
Ch12: voice port: 0/1/0:15.27, codec: None, credits allocated: 15
Ch13: voice port: 0/0/1:15.10, codec: g711ulaw, credits allocated: 23
Ch14: voice port: 0/1/1:15.29, codec: g711ulaw, credits allocated: 23
Ch15: voice port: 0/1/0:15.28, codec: g711ulaw, credits allocated: 15
Ch16: voice port: 0/0/1:15.6, codec: g711ulaw, credits allocated: 15
Ch17: voice port: 0/0/1:15.29, codec: g711ulaw, credits allocated: 23
Ch18: voice port: 0/0/1:15.23, codec: g711ulaw, credits allocated: 23
Ch19: voice port: 0/0/1:15.26, codec: g711ulaw, credits allocated: 23
Ch20: voice port: 0/1/1:15.31, codec: g711ulaw, credits allocated: 23
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
Shared credits: 391, reserved credits: 0
Voice channels allocated: 11
Credits used (rounded-up): 254
Voice channels:
Ch01: voice port: 0/1/0:15.25, codec: g711ulaw, credits allocated: 23
Ch02: voice port: 0/0/0:15.28, codec: g711ulaw, credits allocated: 23
Ch03: voice port: 0/1/0:15.26, codec: g711ulaw, credits allocated: 23
Ch04: voice port: 0/0/1:15.28, codec: g711ulaw, credits allocated: 23
Ch05: voice port: 0/0/1:15.11, codec: g711ulaw, credits allocated: 23
Ch06: voice port: 0/0/1:15.27, codec: g711ulaw, credits allocated: 23
Ch07: voice port: 0/1/1:15.27, codec: None, credits allocated: 15
Ch08: voice port: 0/0/0:15.30, codec: g711ulaw, credits allocated: 23
Ch09: voice port: 0/0/1:15.22, codec: g711ulaw, credits allocated: 23
Ch10: voice port: 0/0/0:15.31, codec: g711ulaw, credits allocated: 23
Ch15: voice port: 0/0/1:15.21, codec: g711ulaw, credits allocated: 23
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 3:
Max signal/voice channel: 42/43
num_of_sig_chnls_allocated: 34
Shared credits: 573, reserved credits: 0
Signaling channels allocated: 34
Voice channels allocated: 0
Credits used (rounded-up): 0
Group: FLEX_GROUP_CONF, complexity: SECURE CONFERENCE
Shared credits: 0, reserved credits: 72
Codec: SECURE_CONF_G711, maximum participants: 8
Sessions per dsp: 9
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 4:
num_of_sig_chnls_allocated: 0
Shared credits: 0, reserved credits: 645
Sessions per dsp: 9
Slot: 0
Device idx: 1
PVDM Slot: 0
Dsp Type: SP2600
dsp 5:
Sessions per dsp: 9
Slot: 0
Device idx: 1
PVDM Slot: 0
Dsp Type: SP2600
dsp 6:
Sessions per dsp: 9
Conference sessions:
Sess01: Credits allocated: 71
Slot: 0
Device idx: 1
PVDM Slot: 0
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
if you need more information to help, let me now. ;)
kind regards
Stefan
01-11-2016 09:41 AM
Hi Stefan,
1. It does look odd that for each G711 call 23 credits is allocated. Each G711 call in flex mode should use 15 credits. I wrote a few documentation a while back to explain a few of the technicalities in this. Please refer to them below.
I am not sure where the 23 is coming from. This might need to be escalated to TAC to get to the bottom of it.
https://supportforums.cisco.com/document/123061/understanding-output-show-voice-dsp-group-all
https://supportforums.cisco.com/document/123126/cisco-pvdm2-and-pvdm3-dsp-creditmips-allocation
2. For the conferencing, it looks as if dsp 6 is the only one with one active conference session going on. We can see that a total of 71 credits were used up out of the reserved 645 credits..
Sessions per dsp: 9
01-13-2016 04:30 AM
Hi Ayodeji,
thanks for your reply. I have already read your documentation. Great work!
We have found an explanation for the 23 credits! It's because we use SRTP with g711 calls.
When we look at the capabilites of the dsp we see that 27 g711_srtp calls per dsp are possible. For that dsp we have 645 credits available. If we divide the available credits with the value of 27 we got the result 23,8. Because Cisco rounds this value down we got the 23!
Voice Channels:
g711perdsp = 43, g726perdsp = 32, g729perdsp = 20, g729aperdsp = 32,
g723perdsp = 0 , g728perdsp = 20, g711_5msperdsp = 28, gsmamrnbperdsp = 20,
ilbcperdsp = 20, isacperdsp = 10, modemrelayperdsp = 20,
g72264Perdsp = 32, h324perdsp = 20,
m_f_thruperdsp = 43, faxrelayperdsp = 32,
maxchperdsp = 43, minchperdsp = 20,
srtp_maxchperdsp = 27, srtp_minchperdsp = 14, faxrelay_srtp_perdsp = 14,
g711_srtp_perdsp = 27, g729_srtp_perdsp = 14, g729a_srtp_perdsp = 24
gnx64_srtp_perdsp = 27
kind regards
Stefan
01-13-2016 05:50 AM
Stefan,
Thanks for updating the thread. Great work (+5)
