03-14-2013 05:48 AM - edited 03-16-2019 04:15 PM
Hi all!
I have a problem in a router 3925. IOS (Version 15.0(1)M2)
This router have two PVDM-3 64, on the motherboard.
The hardware recognizes PVDMs.
VGW-3925-RJO-01#show inventory
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC142218SZ
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC142218T3
However the DSPs that are active are only 4 ...
VGW-3925-RJO-01#show voice dsp group slot all
% Invalid input detected at '^' marker.
VGW-3925-RJO-01#show voice dsp group slot ?
<0-8> NM card slot number
VGW-3925-RJO-01#show voice dsp group ?
all Show all the dsp group details in this box
slot Show all the dsp group in this slot
VGW-3925-RJO-01#show voice dsp group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 26.3.6
Max signal/voice channel: 32/32
Max credits: 480
num_of_sig_chnls_allocated: 32
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 480, reserved credits: 0
Signaling channels allocated: 32
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
Max credits: 480
num_of_sig_chnls_allocated: 31
Transcoding channels allocated: 1
Shared credits: 445, reserved credits: 0
Signaling channels allocated: 28
Group: FLEX_GROUP_XCODE, complexity: HIGH
Shared credits: 0, reserved credits: 35
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 7:
Max credits: 480
Transcoding channels allocated: 14
Shared credits: 0, reserved credits: 480
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
dsp 8:
Max credits: 480
Group: FLEX_GROUP_CONF, complexity: CONFERENCE
Codec: CONF_G729, maximum participants: 8
Sessions per dsp: 5
Slot: 0
Device idx: 0
PVDM Slot: 1
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
All calls are being completed, but using transcoding, which was set up in these DSPs. You know this problem? Is there any way to test these PVDMs remotely? Or only physically?
03-14-2013 06:00 AM
What is the problem exactly ?
03-14-2013 06:03 AM
Hi Paolo!
When I receive calls from the PSTN, several times we can not transfer or make conferences.
03-14-2013 06:20 AM
Update IOS and check again.
03-14-2013 06:29 AM
Paolo,
Thanks for the reply.
Update the IOS is the only option in this case?
