DSP fail on the PVDM-3 64
Hi all!
I have a problem in a router 3925. IOS (Version 15.0(1)M2)
This router have two PVDM-3 64, on the motherboard.
The hardware recognizes PVDMs.
VGW-3925-RJO-01#show inventory
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC142218SZ
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN: FOC142218T3
However the DSPs that are active are only 4 ...
VGW-3925-RJO-01#show voice dsp group slot all
% Invalid input detected at '^' marker.
VGW-3925-RJO-01#show voice dsp group slot ?
  <0-8>  NM card slot number
VGW-3925-RJO-01#show voice dsp group ?
  all   Show all the dsp group details in this box
  slot  Show all the dsp group in this slot
VGW-3925-RJO-01#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 26.3.6
  Max signal/voice channel: 32/32
  Max credits: 480
  num_of_sig_chnls_allocated: 32
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 32
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 2:
  Max credits: 480
  num_of_sig_chnls_allocated: 31
  Transcoding channels allocated: 1
    Shared credits: 445, reserved credits: 0
    Signaling channels allocated: 28
  Group: FLEX_GROUP_XCODE, complexity: HIGH
    Shared credits: 0, reserved credits: 35
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
dsp 7:
  Max credits: 480
  Transcoding channels allocated: 14
    Shared credits: 0, reserved credits: 480
  Slot: 0
  Device idx: 0
  PVDM Slot: 1
  Dsp Type: SP2600
dsp 8:
  Max credits: 480
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 5
  Slot: 0
  Device idx: 0
  PVDM Slot: 1
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
All calls are being completed, but using transcoding, which was set up in these DSPs. You know this problem? Is there any way to test these PVDMs remotely? Or only physically?
paolo bevilacqua
What is the problem exactly ?
