07-25-2018 02:27 AM - edited 03-17-2019 01:14 PM
Hi All
We are currently under a talk on hardware requirement for a new site. There is a backup router in the site which would be used only for 911 calling if the mail router fails. For routing the call we got NIM-FXO. My question here is do we need a PVDM for the call or the one which comes with the card; DM8147 is enough ?
Solved! Go to Solution.
07-25-2018 04:40 AM
This is incorrect statement, FXOs and FXS do require DSPs just like T1, however the newer NIM modules for ISR4Ks come wit sufficient PVDMs for the FXO card and no "additional" PVDMs are needed. This was different on ISR G1 and G2 routers were the FXO cards did not come with PVDMs. So, in short you need PVDMs (DSPs) but you get them with the module.
07-25-2018 02:37 AM
07-25-2018 03:37 AM
You don't need PVDM for FXO. PVDM only used for T1/E1 module
Muaaz Elkamali
07-25-2018 03:50 AM
07-25-2018 04:40 AM
07-25-2018 04:50 AM - edited 07-25-2018 04:51 AM
Thanks Chris
07-25-2018 05:45 AM
Good to know. Normally I don't order PVDM with FXO as you said it come with module.
Muaaz Elkamali
07-26-2018 03:50 AM
Hi Chris,
Does this debug means it is taking the DSP of slot 0/1
Jul 26 08:30:44.863: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
Jul 26 08:30:48.211: lookup_codec_credits: NR=0, ASP=0, codec:5, srtp:0, credit:15
Jul 26 08:30:48.211: flex_dsprm_find_voice_dsp_enhanced_basic: dsp 0: MIPS required 15
Jul 26 08:30:48.211: flex_dsprm_max_potential_credits_reqd: max poten credit: dsp 0, open chnls 0, poten 0
Jul 26 08:30:48.211: flex_dsprm_find_voice_dsp_enhanced_basic: criteria I, max_poten 15, avail 120, dsp_picked 0.
Jul 26 08:30:48.211: dsp 0/channel/credits/locked : channel: 0 credits: 0
Jul 26 08:30:48.212: flex_dsprm_hunt_free_voice_channel: return voice_channel(0/1/0/0), credits(15/15)
Jul 26 08:30:49.798: lookup_codec_credits: NR=0, ASP=0, codec:5, srtp:0, credit:15
