Hello, i have being trying to troubleshoot why incoming calls and outgoing calls to the PSTN is not working on a 2801 router after configuring it to do. Along the line discovered that my FXO ports were just showing amber even after when the router has booted up. Very new to Cisco VOIP but was able to do the following show comands, that's when I realized this could possibly be a DSP issue but don't know how resolve this. Will appreciate if someone could help me out based on this. Here are the output of the show commands I ran:-
sh voice dsp detailed
Warning! DSPs1, in slot 0 are using non-default firmware from flash:
This is not recommended, the default version is 22.5.0
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS
ABRT PACK COUNT
C5510 001 01 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 02 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 03 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 04 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 05 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 06 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 07 None 0.0.0 bad idle 0 0
0 0/0
C5510 001 08 None 0.0.0 bad idle 0 0
0 0/0
*DSP SIGNALING CHANNELS*
ABRT PACK COUNT
C5510 001 01 {flex} 0.0.0 free idle 0 0 0/0/0
0 0/0
C5510 001 02 {flex} 0.0.0 free idle 0 0 0/0/1
0 0/0
C5510 001 03 {flex} 0.0.0 free idle 0 0 0/0/2
0 0/0
C5510 001 04 {flex} 0.0.0 free idle 0 0 0/0/3
0 0/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
ICT_Soln#test dsp device 0 1 reset
*Feb 15 16:46:40.403: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to down
ICT_Soln#
ICT_Soln#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: FAIL, firmware: 0.0.0
Max signal/voice channel: 8/8
Max credits: 160
num_of_sig_chnls_allocated: 4
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 160, reserved credits: 0
Signaling channels allocated: 4
Voice channels allocated: 0
Credits used: 0
0 DSP resource allocation failure
Lastly did a voice test driver:-
DSP Keepalive Status Display:
DSP 1 is not UP, State: 5, Keepalive Sent: 0, Skip 0
DSP 2 Not Exist
DSP 3 Not Exist
DSP 4 Not Exist
DSP 5 Not Exist
DSP 6 Not Exist
DSP 7 Not Exist
DSP 8 Not Exist
I have also tried to interchange the slot on which the pvdm was sitting and still the issue persist.
Solved! Go to Solution.
Check your flash to see if you have a dsp_c5510_flex.rbf file on there - if you do rename it to something else or tftp a copy off and delete it. The DSP should then get the firmware that comes with the IOS version you run.
Aaron
Aaron
Hello Aaron, i checked on the router's flash and the file is not there, what i now did is to copy the file from one the froum on this blog ans installed it on the router and rebooted but the problem still persist. Could this be a faulty PVDM or if i do an IOS upgrade the problem will be solved.
Segun,
You can use the following to test the state of the dsp..my guess the dsp showing a status of bad is faulty and you will have to replace the whole PVDM
MAN_VG#test voice driver
Enter VPM or HDV or ATM AIM or NM-HD-xx or HDV2 slot number : 0
C2800 Debugging Section;
1 - FPGA Registers Read/Write
2 - 5510 DSP test
3 - DSPRM test
4 - HDLC32 test
5 - Quit
Select option : 2
5510 DSP Testing Section:
1 - Reset ALL DSPs
2 - Reset 1 DSP
3 - Download DSPware
4 - CHPIR Enable/Disable
5 - Display c5510 ring
6 - Show HPI RAM
7 - Show eHPI memory thru Relay command
8 - Show Controller
9 - c5510 Keepalive Enable/Disable
10 - Download bootloader using indirect slave access
11 - Write HPI RAM
13 - DSP application download
14 - faked dsp crash
15 - Wait in Firmware Restart Indication
16 - Display DSP Keepalive Status
17 - QUIT
Select option : 16
DSP Keepalive Status Display:------------------you should see an output like this.
DSP 1 is Alive, State: 4, Keepalive Sent: 327216, Skip 566572
DSP 2 is not UP, State: 5, Keepalive Sent: 0, Skip 0-------------------------------DSP2 was faulty in my case.
DSP 3 is Alive, State: 4, Keepalive Sent: 417410, Skip 476382
DSP 4 Not Exist
You can try and reset the DSP and see if it helps, otherwise I am afraid you may have to change the PVDM
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi aokanlawon
Could you please tell me the complete procedure to upgrade the firmware on the DSP Chip and were to download it from ?.
For learning purpose i tried the above command "test voice driver" but it is not availble on my 29XX Series router.
Thanks.
There are two ways to upgrade the dspware (the firmware on the dsp)
1. Upgrade your IOS, becaue dspware is embedded in the IOS
2. Send an email to TAC to get you the required dspware, this will upgrade your dspware regardless of the IOS version you are running
TAC will send you a file to copy to flash. For the C5510 dsp (on most 2800 routers) they will send you a file called dsp_c5510_flex.rbf, which need to be specific for the DSPs that are in the router. Once copied to flash, reboot the router and it will look for these files and use them. Otherwise, it will use the DSPware version that is embedded within the IOS.
The test voice driver will not work for the 2900 routers because they use a different DSPs to the 2800 routers. From the output of that command you can see that the command is for the C5510 dsps.
The 2900 uses dsp type SP2600.
Hello Brov, i already did the test immediately i discovered the issue, its actually in my very first post but here it is again:-
DSP 2 Not Exist
DSP 3 Not Exist
DSP 4 Not Exist
DSP 5 Not Exist
DSP 6 Not Exist
DSP 7 Not Exist
DSP 8 Not Exist
And also reset the DSP which still didnt make the DSP come up, so i guess i will have to replace the PVDM?
Thanks alot.
Segun,
Sorry I missed that. Yes you will have to replace it. You can do an RMA if you have a valid service contract.
Hello Okanlawon, how is work going? Thanks for your support the last time
Now I have been able to purchase a new pvdm and installed it and I did
the following commands to test if the DSP is working fine now. Please
find below the output of the test.
dsp 1:
State: UP, firmware: 22.5.0
Max credits: 160
Credits used: 0
ICT_Soln#sh voice dsp detailed
edsp 001 01 g729r8 p 0.1 IDLE 50/0/1.1
edsp 002 02 g729r8 p 0.1 IDLE 50/0/1.2
edsp 003 01 g729r8 p 0.1 IDLE 50/0/2.1
edsp 004 02 g729r8 p 0.1 IDLE 50/0/2.2
edsp 005 01 g711ulaw 0.1 IDLE 50/0/3.1
edsp 006 02 g729r8 p 0.1 IDLE 50/0/3.2
edsp 007 01 g729r8 p 0.1 IDLE 50/0/4.1
edsp 008 02 g729r8 p 0.1 IDLE 50/0/4.2
edsp 009 01 g711ulaw 0.1 IDLE 50/0/5.1
edsp 010 02 g729r8 p 0.1 IDLE 50/0/5.2
edsp 011 01 g729r8 p 0.1 IDLE 50/0/6.1
edsp 012 02 g729r8 p 0.1 IDLE 50/0/6.2
edsp 013 01 g711ulaw 0.1 IDLE 50/0/7.1
edsp 014 02 g729r8 p 0.1 IDLE 50/0/7.2
edsp 015 01 g711ulaw 0.1 IDLE 50/0/8.1
edsp 016 02 g729r8 p 0.1 IDLE 50/0/8.2
edsp 017 01 g729r8 p 0.1 IDLE 50/0/9.1
edsp 018 02 g729r8 p 0.1 IDLE 50/0/9.2
edsp 019 01 g729r8 p 0.1 IDLE 50/0/10.1
edsp 020 02 g729r8 p 0.1 IDLE 50/0/10.2
edsp 021 01 g711ulaw 0.1 IDLE 50/0/11.1
edsp 022 02 g729r8 p 0.1 IDLE 50/0/11.2
ABRT PACK COUNT
C5510 001 01 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 02 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 03 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 04 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 05 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 06 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 07 None 22.5.0 idle idle 0 0
0 0/0
C5510 001 08 None 22.5.0 idle idle 0 0
0 0/0
ABRT PACK COUNT
C5510 001 01 {flex} 22.5.0 alloc idle 0 0 0/0/0 02
0 62/0
C5510 001 02 {flex} 22.5.0 alloc idle 0 0 0/0/1 06
0 37/0
C5510 001 03 {flex} 22.5.0 alloc idle 0 0 0/0/2 10
0 37/0
C5510 001 04 {flex} 22.5.0 alloc idle 0 0 0/0/3 14
0 36/0
And now here is my current configuration:-
voice service voip
allow-connections sip to sip
sip
registrar server expires max 1200 min 300
voice class custom-cptone NG_customtone
dualtone disconnect
frequency 400 450
cadence 200 400
voice register global
mode cme
source-address 192.168.200.1 port 5060
max-dn 10
max-pool 12
load 3911 SIP3951.8-1-2-9
authenticate register
authenticate realm cisco.com
timezone 25
time-format 24
date-format D/M/Y
mwi stutter
mwi reg-e164
dialplan-pattern 1 270.... extension-length 4
tftp-path flash:
create profile sync 0008183651386931
voice statistics time-range since-reset
voice-card 0
dsp services dspfarm
no local-bypass
control-plane
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone NG_customtone
no battery-reversal
input gain 3
no vad
cptone NG
timeouts interdigit 5
timeouts call-disconnect 3
timeouts ringing 30
timeouts wait-release 3
connection plar opx 106
impedance complex2
description Trunk 49
caller-id enable
sip-ua
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 2
fxo hook-flash
load 7935 P00503010100
load 7960-7940 P0030702T023
load ATA ATA030100SCCP040211A.ZUP
load 7936 CMTERM_7936.3-3-5-0
load 7906 SCCP11.7-2-1-0S
load 7911 SCCP11.7-2-1-0S
max-ephones 12
max-dn 75
ip source-address 192.168.100.1 port 2000
system message ICT Solutions
time-zone 25
time-format 24
date-format dd-mm-yy
voicemail 111
max-conferences 4 gain -6
hunt-group logout HLog
moh music-on-hold.au
web admin system name ictsolutions secret 5 $1$bHmJ$XJ9ieuBgs7nGekELyXt9Q1
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 100 blind
secondary-dialtone 9
create cnf-files version-stamp 7960
ephone-dn 3 dual-line
number 106
name Reception
call-forward busy 111
call-forward noan 111 timeout 15
mwi-type both
ephone 9
mac-address F025.7278.DD41
button 1:3
Now I have made calls from the PSTN to the phone line which is
attached to FXO port 0/0/0 but didnt get any ringout, do I need to
allocate the dsp resources for transcoding. Because from the Show
voice dsp detailed its showing dsp not allocated and idle.
Thanks inadvance
Segun,
OK..So is it only ringing you dont get? does the call connect? In this call setup you dont need any transcoder..Your DSP will encode your G729 codec coming from your ephones to the 64Kbps PCM used by the PSTN.
Ca you send
debug voip ccapi inout
debug vpm signal
Hello Brov. I configured the wrong plar extension, swapped it for another DN instead of the FrontDesk extenstion. Thanks alot, Really appreciate
