05-21-2018 02:56 AM - edited 03-18-2019 12:25 PM
i have an issue with dsp it affects my outbound calls to pstn and my internal calls though h323 trunk to avaya system it gives randomly fast busy tone i used rtmt it gives that there is out of resources i can't catch the issue when i debug i get disconnect cause 47
sccp local GigabitEthernet0/0
sccp ccm 192.168.6.31 identifier 1 version 7.0 --gateway
sccp ccm 192.168.6.21 identifier 3 version 6.0 -- sub (where call manager service is active)
sccp ccm 192.168.6.20 identifier 2 version 6.0 --- publisher(call manager service not active)
sccp
sccp ccm group 2
associate ccm 2 priority 1
associate ccm 3 priority 2
associate profile 2 register xcoder2
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register gwcoder
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
output of sh sccp :
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 192.168.6.31
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.6.20, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 2
Trustpoint: N/A
Call Manager: 192.168.6.21, Port Number: 2000
Priority: N/A, Version: 6.0, Identifier: 3
Trustpoint: N/A
Call Manager: 192.168.6.31, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Transcoding Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.6.21, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 20, Reported Max OOS Streams: 0
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Active Call Manager: 192.168.6.31, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Supported Codec: g729br8, Maximum Packetization Period: 60
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
1 9 28.3.14 UP N/A FREE xcode 1 - - -
1 10 28.3.14 UP N/A FREE xcode 1 - - -
1 11 28.3.14 UP N/A FREE xcode 2 - - -
1 11 28.3.14 UP N/A FREE xcode 1 - - -
1 12 28.3.14 UP N/A FREE xcode 2 - - -
1 13 28.3.14 UP N/A FREE xcode 2 - - -
Total number of DSPFARM DSP channel(s) 20
05-21-2018 05:54 AM
Is that the full SCCP config? I'm not seeing a "maximum sessions" line on your transcoder.
05-21-2018 07:10 AM
05-21-2018 05:59 AM
05-21-2018 07:10 AM
05-21-2018 11:57 AM
05-21-2018 12:03 PM
I agree with Nipun Singh Raghav, how are you sure the issue is related to transcoders?
If CUCM is generating the "out of resource" message it could be because it needs a transcoder, or an MTP, MOH, etc.
05-22-2018 02:11 AM
05-22-2018 04:37 AM
Others are helping with the transcoder issue, but your comment about not being able to select a-law over u-law in CUCM caught my eye. What version of CUCM are you using? If you have 9.0 or later, Cisco introduced the Audio Codec Preference Lists feature, which allows you to alter the codec selection list in CUCM. Specifically, it will allow you to tell CUCM to prefer a-law over u-law which may solve your problem with the transcoder since you won't need one.
Here is a link to the 9.1 CUCM Admin Guide which addresses this feature. The information is relevant to all versions after 9 as well:
05-23-2018 06:41 AM
05-21-2018 08:53 PM
Please see blow post as it has some useful information related to your problem:
Also, try using SIP Trunk between CUCM and Voice Gateway and H323 between Voice Gateway and PSTN/Avaya.
05-23-2018 06:44 AM
