DSPFarm 2851 / NM-HD-2V
dangilley1
Hi Everyone,
Quick question. I'm trying to set up cbarge on CME 8.6 running on a 2851. I see that I need dsp to accomplish this. Can I use  nm-hd-2v (has 8 dsp?) for dsps for cbarge (and then fxo/fxs? or without vic card?) or must I use a nm-hdv2 with pvdm2s?
Thank you,
Dan
Dan,
This gives a major clue as to whats going on:
Application : SCCP   Status : NOT ASSOCIATED
You'll need to create a loopback, then associate the dspfarm profile via SCCP so it registers. You'll need all of the following, with some modifications based upon your config:
sccp local Loopback0
sccp ccm identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate profile 1 register CME-CONF
voice-card 1
dspfarm
dsp services dspfarm
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
telephony-service
sdspfarm tag 1 CME-CONF
no privacy
conference hardware
Remember to bring the dspfarm up with no shut.
Best,
David
Please remember to rate helpful resonses and identify correct answers.
5 Replies 5
paolo bevilacqua
You don't need any NM for DSP on an ISR router. Just install PVDM2-xx directly on the motherboard.
Hi Paolo,
Thanks for the reply. I don't have any PVDM2s but I do have a NM-HD-2V without FXO/FXS that I was hoping to be able to use for cbarge conferences, but I can't seem to get it to work. Is it possible?
Dan
CME#sh dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : DOWN
Profile Operation State : DOWN
Resource Provider : FLEX_DSPRM   Status : NONE
Number of Resource Configured : 2
Number of Resource Available : 0
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
CME#sh voice dsp group all
DSP groups on slot 0:
DSP groups on slot 1:
dsp 1:
  State: UP, firmware: 28.3.5
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 0
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  0 DSP resource allocation failure
Chris Deren
Can you post "sh run"?
Hi Chris,
I reloaded the router after I was unsuccessful just to remove anything I did that may have been erroneous. I followed the post by aokanlawon in the thread below to the letter:
https://supportforums.cisco.com/thread/2011036
The only thing I did additionally was to add the cbarge softkey to the ephone template. I did get the same error in the thread above when dialing the conference # (Can not complete conference), and I tried to remove conference hardware from telephony-service as mentioned in that thread as well.
Thank you,
Dan
Dan,
sccp
sccp ccm group 1
voice-card 1
dspfarm
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
telephony-service
no privacy
conference hardware
Best,
David
