3073
DSPs - State: APP_DNLDING - conference max session 0
hi,
i have a 2901 with 15.2(2)M and one PVDM3-16 installed. I try to get working an ad-hoc conference but when i enter the command
dsp profile 1 conference
maximum session <0-0>
0 sessions?
Router2901#sh voice dsp group all
DSP groups on slot 0:
dsp 1:
State: APP_DNLDING, firmware: 0.0.0
Max signal/voice channel: 16/16
Max credits: 240, Voice credits: 240, Video credits: 0
num_of_sig_chnls_allocated: 0
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 0
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
0 DSP resource allocation failure
Router2901#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : DOWN
Profile Operation State : DOWN
Application : SCCP   Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : NONE
Number of Resource Configured : 0
Number of Resource Available : 0
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Total number of DSPFARM DSP channel(s) 0
what could it be?
thank
6 REPLIES 6
ronpatel
Collaborator
HI
Can you please share show diag of the router.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
here is the show diag
Slot 0:
C2901 Mother board 2GE, integrated VPN and 4W Port adapter, 2 ports
Port adapter is analyzed
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
Hardware Revision        : 1.0
Part Number              : XXXX
Board Revision           : B0
Deviation Number         : 0
Fab Version              : 03
PCB Serial Number        : XXXX
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Processor type           : 00
Product (FRU) Number     : PVDM3-16
Version Identifier       : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 42 30
0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 32 38
0x20: 30 38 50 58 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
Total platform memory : 524288K bytes
Total 2nd core memory : 0K bytes
Start of physical address for 2nd core : 0x80000000
Virtual address start of 2nd core memory : 0x0 - 0x0
2nd core configured disabled
L2 cache ways for 2nd core : 0
thx Konrad
HI
This issue happens when you have not accepted license aggrement EULA in the router. Have you accepted the EULA and reload the router after it.
Ronak patel
Please rate helpful posts.
i can't remind, but i tried now with following command
license accept end user agreement
yes
reload
but it's the same behaviour
There was a bug but it got resolved in 15.1.2 release.
Can you share the sh run of the router.
regards
Ronak patel
Rate helpful posts.
Hi Ronak,
thanks for your help - DSP hardware failure was the problem.
Konrad.
Create
Recognize Your Peers
Content for Community-Ad
