02-28-2013 01:47 AM - edited 03-16-2019 03:58 PM
Hi Guys,
I am facing an issue in which DTMF tones are not being forwarded when calling outbound inbound is working fine.
I have an Alcatel PBX connected to a h323 gateway and then forwarded to the h323 gateway with the SIP trunk.
The PBX is sending the dtmf using h245 signal and is being recieved by our gateway. The SIP gateway on the other hand seems to be getting the digits but the events seem to be wrong.
this is the dial-peer config on the client gateway and the h245 asn1 debugs from the client gateway
dial-peer voice 9 voip
translation-profile outgoing ANI
destination-pattern 00T
session target ipv4:10.64.120.11
dtmf-relay rtp-nte
no vad
Feb 22 06:38:12.296: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : signal :
signalType "0"
duration 60
rtp
logicalChannelNumber 1
Feb 22 06:38:13.008: H245 MSC INCOMING ENCODE BUFFER::= 6D810766C0003B000000
Feb 22 06:38:13.008: H245 MSC INCOMING PDU ::=
signalType "6"
duration 60
rtp
Help Please thanks
Solved! Go to Solution.
02-28-2013 03:57 AM
Hassan...From your config the call flow does not look correct..
You have customer gateway, and sip gateway
Please describe the call flow correctly...There are two gateways here
Alcatel---h233--CUBE(CE)--------inbound dp=h323----------->sipgw--------outbounddp=sip----------->ITSP
You have only showed the outbound sip dial-peer. There must be an inbound dial-peer from the CE router to the SIP gateway.
From the logs..
The inbound dial-peer on CE router is dial-peer voice 2 voip. Do you have dtmf-relay h245 on that?
On the SIPGW
inbound dial-peer=1 (do you have dtmf relay h245 on this?
outbound dialpeer=100
I can also see that you pressed digit 29014( this were sent to the ITSP)
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
02-28-2013 02:23 AM
First of all you need to draw your call flow for us..So we can get a better picture..eg
alcatel--h323----cube---sip---ITSP is this correct..if it is not then draw up the correct flow
Second the config on your dial-peer is wrong. You cant use dtmf-relay rtp-nte on a h323 dial-peer...
Here are my suggestions...
Configure your inbound h323 dial-peer from alcaltel with dtmf-relay h245
!#inbound dial-peer
dial-peer voice xxx voip
dtmf-relay h245-alphanumeric
and configure outbound sip dial-peer to sip trunk to use digit-drop
//outbound to ITSP SIP dial-peer
!#NEW CONFIG
dial-peer voice yyy voip
dtmf-relay rtp-nte digit-drop
if it doesnt work...
please send us
debug voip rtp session named-event
debug ccsip messages
debug voip ccapi inout
02-28-2013 03:23 AM
Yes the Flow is as above. I have tried it using the digit drop command but it didnt work
The Dial-peer on the SIP router is
dial-peer voice 100 voip
destination-pattern 00441743742310
session protocol sipv2
session target sip-server
no vad
dial-peer on the customer gateway
no vad
dial-peer voice 1 voip
destination-pattern 2310
session target ipv4:10.116.32.12
no vad
02-28-2013 03:57 AM
From the logs..
On the SIPGW
02-28-2013 04:18 AM
HI,
yes there is a dial-peer 2 on the CE router and it was missing the h245 command do you think that could be the issue?
the dial-peer now is
incoming called-number .
no vad ial-peer voice 2 voip
no vad
The inbound dial-peer is as such on the SIP router
translation-profile incoming SIP-INBOUND
media flow-around
signaling update from gtd calling
voice-class codec 1
dtmf-relay rtp-nte sip-kpml
no vad
02-28-2013 04:29 AM
Yes that can be an issue. If your inbound dial-peer on the sip gateway is a sip dial-peer then your config is wrong
Your outbound dial-peer from CE router is a h323 dial-peer, your inbound dial-peer that receives that call has to be a h323 dial-peer....
So your dial-peer voice 1 voip need to be changed to h323 dial-peer..You should then remove dtmf-relay rtp-nte sip-kpml and add only h245-lapha
May I ask why you are not doing a complete sip integration...
If your pbx does not support sip..
You can do inbound h323 from pbx to h323 and then outboud from CE router to SIPGW to be sip, then inbound to SIPGW to be sip and outbound to ITSP to be sip
Alcatel--inboundp=h323------->CERouter----outboundp=sip--------->SIPGW--------inbounddp=sip---SIPGW-----outbounddp=sip---------------->ITSP
In this call flow, you will then configure dtmf relay rtp-nte digit drop on sip dial-peers and h245 only on the inbound dp from alcatel to CE router
02-28-2013 05:04 AM
Its a mixed sort of a network and thats how it got handed over. The issue got resolved i set the outgoing dial-peer to rtp-nte as our SP was accepting that and the incoming dial-peer to h245.
Thanks for all your support i learned a lot from this discussion thank you
Hassan
02-28-2013 05:12 AM
Glad I could help. But you have not rated any of my posts. You also have not marked the thread as answered. it is useful for others who have similar problems. It is also good to encourage people like me
