dtmf issue on uc540
Your CUE is configured for rtp-nte
ccn subsystem sip
gateway address "10.1.10.2"
dtmf-relay rtp-nte
end subsystem
ccn subsystem sip
Please change this to
conf t
ccn subsystem sip
dtmf-relay sip-notify
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
19 Replies 19
Bruno Rangel
Check if you CUE is working properly, once that is not working fron inside
Cheers
Bruno Rangel
Please remember to rate helpful  responses using the stars bellow and identify helpful or correct answers .
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
What do you mean by check from inside???
i have already checked its working fine....its pinging, I can open cli of cue,Gui also works fine.
I mean if it´s working from a Internal extension
mohd abdul malik wrote:
Not only i am facing this issue when i am calling from outside but also  internally therfore am guessing this issue is related to configuration
Cheers
Bruno Rangel
Cheers
Bruno Rangel
nope its not working for internal extensions also.
Is my configuration alright??
Hi Abdul,
show run (From the CUE)
Kevin
Hi kevin,
Thanks for taking interest in my issue I really appreciate your concern for other.
Ayodeji Okanlawon
Abdul,
You didnt post the dial-peers for the CUE. Do you have sip notify configured on the dial-peer pointing to CUE on the UC520?
Hi Aokanlawon,
I have posted the dialpeer in my initial question, Please have a look.
Now i have also done the dtmf-relay sip notify configuration on the dial-peer voice 750 voip.
destination-pattern 750
session protocol sipv2
session target ipv4:10.1.10.1
codec g711ulaw
no vad
Still its not working
Bruno Rangel
You received busy tone ? Post the output of debbug voice ccapi inout.
Also try no incoming called number . in your DP
Cheers
Bruno Rangel
Please check the attached requested debugs.
Can you post your full sh run..What is configured on dial-peer 102?
Well 102 is an incoming dial-peer.
but its taking the dial peer 750 to route the cals to cue.
ccn subsystem sip
dtmf-relay rtp-nte
end subsystem
ccn subsystem sip
conf t
ccn subsystem sip
