Community Helping Community
138
Highlighted
Beginner
DTMF Mismatch SIP to MGCP Fax
Having a DTMF mismatch issue.  The SIP error received is 503 service unavailable cause=47.  Codec Mismatch.  When looking at the traces I get the following.
If I don't have a transcoder I get
isMTPNeededForMismatchOrConfig, MTPNeededDueToDTMFCapMismatch(2833/OOB) mtpinsertionReason=1 dtmfMTPSide=1
sendMTPXcoderAllocationRequest, allocate MTP
MRM::getMtpDeviceGivenMrgl DeviceName=MTP_10 DeviceType=110
sendMtpAllocateRequestToDevice MtpResource=MTP_10
getResourcesAllocated -- DeviceName=MTP_10 Ci=31719716 ResourceCount=1
getResourcesAllocated -- Logging RegionA=US164-LEG-SME-RGN Caps and MTP/XCoder Region=Default Caps
logCapabilitiesinTrace -- MTP/XCoder Device Caps = 4 2 25 257 259 258
logCapabilitiesinTrace -- Device Caps = 4 2
matchCapabilities-- savedOption=0, PREF_LIST, regionA=Default regionB=US164-LEG-SME-RGN latentCaps(A=0, B=0) kbps=8, capACount=6, capBCount=2
getResourcesAllocated -- Logging RegionB=VERIZON-SIP-TRUNK-FAX Caps and MTP/XCoder Region=Default Caps
logCapabilitiesinTrace -- Device Caps = 4 2 11 12 15 84 10 83 82 9 107
matchCapabilities-- savedOption=0, PREF_LIST, regionA=Default regionB=VERIZON-SIP-TRUNK-FAX latentCaps(A=0, B=0) kbps=64, capACount=6, capBCount=11
getResourcesAllocated -- No matching caps for either side A or side B, MTP not allocated
getResourcesAllocated -- match1=0 match2=2
getResourcesAllocated -- allocateErrBitset=0x21
SendMTPResourceErrToSender - ERROR AllocateMtpResourceReq failed
If I have an IOS transcoder in the MRG
I get this
getMtpDeviceGivenMrgl DeviceName=MHO-NMS-TRANS1
resource_rsvp_AllocateMtpResourceErr Device=MHO-NMS-TRANS1 deviceCapIntersec=9
adjustDeviceTblMTP - Codec Mismatch
disconnOnResourceAllocationFailure, ERROR disconnOnResourceAllocationFailure - fails to allocate MTP/XCoder,connCount=2
The MGCP router is a VG204 and has this command
mgcp dtmf-relay voip codec all mode out-of-band
I have tried changing this to
mgcp dtmf-relay voip codec all mode nse
to try to not have to allocate an MTP or transcoder but is has not resolved the issue.
Any help would be very much appreciated.
3 REPLIES 3
VIP Advisor
Re: DTMF Mismatch SIP to MGCP Fax
On your SIP config, which DTMF technologies are you listing? Sounds like it's just rtp-nte. If so, enter sip-kpml after it too. You really should have one of each: inband/out of band, to avoid these types of issues. CUBE can DTMF interwork between just about all, if not all, DTMF relay types. That's relay types, which exlcludes DTMF in the audio stream, in which case a DSP is needed.
Anthony Holloway
If you found this post helpful, please consider clicking that helpful button!
And for a limited time, by marking helpful posts, you're also helping Doctors Without Borders
Beginner
So the whole path is third party SIP device Fax Machine -> CUCM Leaf 1 -> CUCM SME -> CUCM Leaf 2 -> VG202 - Fax machine
So no CUBE router involved at the time. DTMF relay is set to No Preference for all SIP trunks. I have tried to set the MGCP dtmf-relay to nte-ca as well but the traces still show that there is a mismatch between 2833 and OOB.
VIP Advisor
I see. Thanks for the clarification on the topology, and the commands you've tried. Do you have the fm-package listed in MGCP? Is your MGCP gateway pulling config from CUCM?
Can you share the Leaf 1 SIP messages to/from the fax server, and the Leaf 2 MGCP packets debug, for a sample call? Please note what state the configuration is in for the debug.
As a pondering thought, it sounds like perhaps the SIP fax device doesn't support any DTMF relay at all, and so, it might not be possible to configure the MGCP gateway to avoid an MTP/XCODE. You may have to just use the service parameter in CUCM at the leaf level to not fail call if MTP allocation fails, and do not provide any MTP/XOCDE to the end points.
Anthony Holloway
Content for Community-Ad
FusionCharts will render here
