11-22-2019 11:28 AM
Having a DTMF mismatch issue. The SIP error received is 503 service unavailable cause=47. Codec Mismatch. When looking at the traces I get the following.
If I don't have a transcoder I get
isMTPNeededForMismatchOrConfig, MTPNeededDueToDTMFCapMismatch(2833/OOB) mtpinsertionReason=1 dtmfMTPSide=1
sendMTPXcoderAllocationRequest, allocate MTP
MRM::getMtpDeviceGivenMrgl DeviceName=MTP_10 DeviceType=110
sendMtpAllocateRequestToDevice MtpResource=MTP_10
getResourcesAllocated -- DeviceName=MTP_10 Ci=31719716 ResourceCount=1
getResourcesAllocated -- Logging RegionA=US164-LEG-SME-RGN Caps and MTP/XCoder Region=Default Caps
logCapabilitiesinTrace -- MTP/XCoder Device Caps = 4 2 25 257 259 258
logCapabilitiesinTrace -- Device Caps = 4 2
matchCapabilities-- savedOption=0, PREF_LIST, regionA=Default regionB=US164-LEG-SME-RGN latentCaps(A=0, B=0) kbps=8, capACount=6, capBCount=2
getResourcesAllocated -- Logging RegionB=VERIZON-SIP-TRUNK-FAX Caps and MTP/XCoder Region=Default Caps
logCapabilitiesinTrace -- Device Caps = 4 2 11 12 15 84 10 83 82 9 107
matchCapabilities-- savedOption=0, PREF_LIST, regionA=Default regionB=VERIZON-SIP-TRUNK-FAX latentCaps(A=0, B=0) kbps=64, capACount=6, capBCount=11
getResourcesAllocated -- No matching caps for either side A or side B, MTP not allocated
getResourcesAllocated -- match1=0 match2=2
getResourcesAllocated -- allocateErrBitset=0x21
SendMTPResourceErrToSender - ERROR AllocateMtpResourceReq failed
If I have an IOS transcoder in the MRG
I get this
getMtpDeviceGivenMrgl DeviceName=MHO-NMS-TRANS1
resource_rsvp_AllocateMtpResourceErr Device=MHO-NMS-TRANS1 deviceCapIntersec=9
adjustDeviceTblMTP - Codec Mismatch
disconnOnResourceAllocationFailure, ERROR disconnOnResourceAllocationFailure - fails to allocate MTP/XCoder,connCount=2
The MGCP router is a VG204 and has this command
mgcp dtmf-relay voip codec all mode out-of-band
I have tried changing this to
mgcp dtmf-relay voip codec all mode nse
to try to not have to allocate an MTP or transcoder but is has not resolved the issue.
Any help would be very much appreciated.
11-22-2019 02:24 PM
11-22-2019 05:06 PM
So the whole path is third party SIP device Fax Machine -> CUCM Leaf 1 -> CUCM SME -> CUCM Leaf 2 -> VG202 - Fax machine
So no CUBE router involved at the time. DTMF relay is set to No Preference for all SIP trunks. I have tried to set the MGCP dtmf-relay to nte-ca as well but the traces still show that there is a mismatch between 2833 and OOB.
11-24-2019 11:46 AM
