01-24-2012 02:49 PM - edited 03-16-2019 09:11 AM
Im working on some CUBEs and they are working great with my provider, CUCM and phones. But I have an issue coming across a GK site from a remote CUCM cluster via H323. When the call goes from CUCM---GK---CUCM---CUBE----SIP Provider, my DTMFs are dead. But if I go from my CUCM----CUBE---SIP Provider, DTFM is fine.
I have on my dial peer in CUBE: DTMF-relay RTP-NTE. Im wondering if I should either change this to dtmf-relay h245-alphanumeric or should I create a seperate dial-peer just for the inbound H323 calls from my remote GK clusters that will use dtmf-relay h245 and leave my CUCM SIP incoming on RTP-NTE?
Thanks!
01-24-2012 03:52 PM
You can have multiple dtmf-relay on dialpeer. You could try dtfm-relay rtp-nte h245-alphanumeric h245-signal.
01-24-2012 03:55 PM
Yeah, that’s what I was going to do next.
So how would it look then? All my calls from CUCM look like this:
dial-peer voice 1 voip
description lan side dial peer
preference 2
session protocol sipv2
session target ipv4:x.x.x.x
incoming called-number 5000
voice-class codec 1
voice-class sip options-keepalive up-interval 100 down-interval 50 retry 6
voice-class sip bind control source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
Do I create another dial-peer with alphanumeric then?
Thanks!
01-24-2012 06:14 PM
Just the change the dtmf-relay line to
Some times you have to change the rtp payload type depends on what event Service provider supports.
We had to add these lines in the outbound/inbound dial-peers.
rtp payload-type nse 127
rtp payload-type nte 100
