DTMF tones on SIP Trunk
skatukam
We have estabilshed SIP trunk between Cisco CCM and Nortel Meridian. We are able to make calls But DTMF tones are not working on the SIP Trunks.
Cisco CCM 5.0.2
Nortel meridian 81c
Can any one suggest possible solution
5 Replies 5
miron.kobelski
SIP sends DTMF inband (RFC 2833) and you need MTP for this in CCM.
thanks, this is already configured.
Iam sending the calls to Nortel, nortel receivs G711U In-band DTMF, but where as SIP trunk only supports RFC 2833 RTP.
How can do the transcoding here. i donot have any gateways or routers to do the transcoding, is there any software level transcoding available in ccm.
Anonymous
Not applicable
Would need detailed CCM Traces to determine the exact cause, but you may be hitting CSCsh40465, which is fixed in 5.1(3).
Anonymous
Not applicable
And by detailed CCM traces I mean - detailed CCM traces of a phone registering on the CCM side, and a call out the SIP Trunk.
Hello, I am facing the same issue with Nortel interop:
Nortel CS1000M --> (IP) Cisco VG --> Call Manager 6
Calls got established but DTMF not transmitted. Do I need to upgrade the VG to CUBE IOS?
Any other options available to solve the interop issue?
Appreciate your feedback.
Wil
