ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Dual BRI-Lines
Hi all,
I have two BRI Lines on a CCME.
1-BRI 0/2/0
2- BRI 0/3/0
I have an extension 0036, if any body make International kal from 0036 extension, the call should be route through BRI-0/3/0 ...
If any body make international call from any other extension call should  pass through BRI-0/2/0 ......
i did the following configuration, but sometime call is passing through  BRI-0/2/0 or some time through BRI-0/3/0...
Can any body suggest, what mistake im doing !!!
voice translation-rule 1
rule 1 /4350048/ /7001/
rule 2 /4350052/ /7002/
rule 3 /4350059/ /7003/
rule 4 /4350072/ /7004/
voice translation-rule 2
rule 1 /^0036/ /44350036/
voice translation-rule 3
rule 1 /.*\(....\)/ /\1/
voice translation-profile NEW-BRI
translate calling 2
voice translation-profile NEW-BRI-Incoming
translate called 3
voice translation-profile PSTNIN
translate called 1
voice-card 0
no dspfarm
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn overlap-receiving
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/3/0
no ip address
isdn static-tei 0
interface Dialer1
no ip address
voice-port 0/2/0
translation-profile incoming PSTNIN
voice-port 0/2/1
voice-port 0/3/0
translation-profile incoming NEW-BRI-Incoming
translation-profile outgoing NEW-BRI
voice-port 0/3/1
dial-peer voice 30 pots
destination-pattern 900T
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/3/0
prefix 00
dial-peer voice 31 pots
direct-inward-dial
port 0/2/0
prefix 00
3 REPLIES 3
Highlighted
Participant
Re: Dual BRI-Lines
     From your current config you have two dial-peers with the same preference, so the choice of BRI will be RANDOM
     If you want to control certain phones using certain voice ports I would use Class of Restriction, see guide http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
     If your users are well behaved you could use different access digits for each port.
Craig
Highlighted
Beginner
Re: Dual BRI-Lines
Hi Craig,
Thanks for your reply.
Alright let me try this by tomorrow.
Wat about incoming calls ???
I need if some body from outside calls to 0036 call should come from BRI-0/3/0 & if to other extension call should come through 0/2/0 ??
Highlighted
Hall of Fame Master
Re: Dual BRI-Lines
Incoming depends by telco, check with them.
