01-28-2013 05:37 AM - edited 03-16-2019 03:24 PM
Hi All
Where can I find a 8.6(2) image for a be6k ?
Philippe
01-28-2013 05:50 AM
You can get the ISO from this link: http://software.cisco.com/download/release.html?mdfid=283783676&flowid=26062&softwareid=282074295&release=8.6(2a)SU2&relind=AVAILABLE&rellifecycle=&reltype=latest
You'll need a CCO account to be able to download the ISO File.
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
01-28-2013 05:58 AM
Thanks but I need a bootable version, we start from scratch . . .
Philippe
01-28-2013 06:04 AM
Hi Phillippe
In that case when you purchase CUCM or an upgrade you should get the media phyically, or via eDelivery.
Have you made a purchase?
Aaron
01-28-2013 06:28 AM
We purchased directly from Cisco but there was no dvd for the callmanager
That's our problem
09-29-2015 01:14 PM
Hello Friends,
How many and what type of pre loaded ISO does the BE 6000M/H have, in the datastore, for default?
I´m planning to install a BE 6000M version 10 and I need that information.
09-29-2015 01:27 PM
Below doc covers the list of software that has been preloaded.
01-28-2013 06:16 AM
You can convert the ISO to a bootable CD but is not suported by CISCO and it's not recomended for a production enviorment.
Like Aaron said, the recomended way is to buy the licence.
01-28-2013 06:30 AM
Can you explain me how to do this ?
We have the PAK license, our problem is that there is no physical dvd in the box.
Philippe
01-28-2013 07:07 AM
I recomended you contact a Cisco representative for your country. They will help you to get a DVD for Call Manager.
This link will help you:
http://www.cisco.com/web/siteassets/contacts/international.html#~tab-b?reloaded=true
01-28-2013 07:27 AM
If you ordered eFulfillment SKUs (they begin with L-) then you will be given the option to download a bootable ISO when you activate the PAK code for a license. If you ordered physical media then Cisco will be shipping your DVDs in white 8.5x11 enevelopes. These will also include the paper PAKs to obtain the license file. Always maintain your PAK codes in a safe place after installation; they act as your serial numbers.
Ordering direct from Cisco is rather unlikely unless you are channel partner with DVAR status. Whomever processed your order can assist further if you have not obtained your physical or electronic PAKs.
Please remember to rate helpful responses and identify helpful or correct answers.
01-28-2013 07:38 AM
I didn't know end custormer could buy directly from Cisco...
