04-19-2015 07:26 PM - edited 03-17-2019 02:43 AM
How many lines does the DX-650 support? The data sheet doesn't seem to say. Prime Collaboration Provisioning's template seems to support 2 lines. But since this is a touchscreen without physical key limitations, I assumed the number should be higher.
Looking directly at the device via CUCM, it has 2 by default, with a third I could add. But I'm going to need 4.
Solved! Go to Solution.
04-19-2015 08:26 PM
Hi Thomas,
DX650 will support a maximum of 15 lines.
The terms lines and calls can be easily confused.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cdce/dx600/user/10_1_1/english/DX60_BK_C6E8877C_00_cisco-dx600-user-guide-10_1_1/DX60_BK_C6E8877C_00_cisco-dx600-user-guide-10_1_1_chapter_010.html
You can recreate the same on your DX650 to confirm it as well.
Manish
04-19-2015 08:26 PM
Hi Thomas,
Manish
