09-27-2020 12:19 AM
We have cisco DX650 phones with android version 4.1.1 and firmware version sipdx650.10-2-5-215, is there a way I can upgrade the Android version ?
I need to download apps that only supported to Android 4.4 and above.
Solved! Go to Solution.
09-27-2020 05:47 AM - edited 09-27-2020 06:56 AM
09-27-2020 01:20 AM
Hello @Lamki911 ,
There are various posts on Community regarding upgrading the DX650, for example:
Additionaly, you may find useful the following documentation:
George
09-27-2020 01:37 AM
Hi George,
Thanks for your fast response.
I already upgraded the firmware to the latest (sipdx650.10-2-5-215), but I cannot find a way to update android version.
Does this phone support an Abdroid verion above 4.1.1 ?
09-27-2020 03:38 AM
Unfortunately I haven;t seen that working on any version above 4.1.1, I believe this is not supported by maybe worth checking this with a Cisco Partner
George
There is no upgrade for android.
09-28-2020 01:13 PM
