07-18-2015 10:36 AM - edited 03-17-2019 03:41 AM
I created a device with the proper MAC address and one DN for a DX650.
I use option 150 to set tftp server via dhcp.
So when the DX650 get's its ip address, it shows the appropriate cucm as tftp server.
After a couple of reboots, it finally figured out it's suppose to down load the latest firmware 10.2.4.46 and then it rebooted.
However it does not register.
What could be the issue?
Solved! Go to Solution.
12-09-2015 08:34 AM
In my case, it was because CUCM 10.5.x had a bug regarding use of a CA Certificate key len of 4096. Not supported.
The root CA is using a key len of 4096. This keylen is not supported due to defect CSCur67631. We regenerated the callmanager.pem, updated CTL file, restarted tomcat, callmanager service and TFTP. After that DX650 started to work.
07-18-2015 01:42 PM
Can you share cucm traces to see where the registration is failing
07-18-2015 03:05 PM
12-09-2015 07:19 AM
Have you resolved this issue. I am trying to register my new dx650. added cop file and restarted tftp but its not registering. It is getting ip & tftp. but its saying phone features unavailable.
12-09-2015 07:20 AM
a clusterwise reboot required . have you performed that
12-09-2015 08:39 AM
nope. I tried to reboot pub and manully register it.. we have 2 more sub..
12-09-2015 08:34 AM
06-25-2016 07:14 AM
Thank you so much for posting this, your a life-saver, I had the same problem in CUCM 11. FYI for others who might experience this, you have to do this in the order John specified, or it will not work, as I found out by restarting the services in a different order. Prior to restarting services, update the CTL, as John stated, and to update the CTL file go to command line of CUCM and enter the command:
utils ctl update CTLFile
07-18-2015 04:34 PM
I see in the pcap that it is trying to
GET /SEP...
and then a not found.
But when I manually get that same file it can download it fine.
However, I do not have a / in front of it. Why is there a slash in front of it?
07-20-2015 08:56 AM
07-21-2015 09:55 AM
