Highlighted
Beginner
Re: Dynamic Hunt Group Membership - Key not active here
Thank you very much, went to load 8.0(10) then 8.1(2) all is working fine now.
Highlighted
Beginner
Having the same problem on
Having the same problem on CME 10.0 + firmware 9-3-1.
Under telephony-service, I have following two lines,
 hunt-group logout HLog
 fac standard
then in ephone-dn, added ephone-hunt login
The HLog key is grey-out. dialed by *3 didn't work either. Same config on CME8.8+F/W 9-2-3 works fine.
Took out the hunt-group logout HLog under telephony-service, the key appeared as normal but didn't do anything when pressed on it.
Not sure this is firmware issue? But the new phone has to use 9-3-1 or above.
Beginner
David,Did you ever figure
David,
Did you ever figure this out?  Running into the same issue...
Highlighted
Hi,Open new thread is better
Open new thread is better than replying a thread has 5 years old
Anas
