07-13-2018 06:07 AM - edited 03-17-2019 01:11 PM
Most of our sites make use of Shared lines for incoming calls from the public which works great when all the phones are registered to our CUCM but when we loose our WAN and drop into E-SRST not all the phones configured with the Shared Lines will ring or be able to answer an incoming call on that line. In our test lab I am able to simulate this problem and have narrowed it down to what appears to be a limitation, only the first 16 phones that register in E-SRST get the shared line. All other phones that register after that still show the line on the phone and work with the exception that the shared line does not ring and they can't answer incoming calls on that line. Does anyone know if this is a hard limitation or any work a round in E-SRST Config??
Routers: 4331's and 2911's
Phones: 7841's and 8851's running SIP firmware
Sample Config below with IP's and DN's removed
voice register global
mode esrst
no allow-hash-in-dn
system message "Phone Running in Failover Mode"
max-dn 30
max-pool 22
voice register dn 1
number xxxxxxxx
shared-line max-calls 4
voice register dn 2
number xxxxxxxx
voice register pool 5
id network xxx.xxx.xxx.xxx mask xxx.xxx.xxx.xxx
preference 2
no digit collect kpml
voice-class codec 1
busy-trigger-per-button 4
Solved! Go to Solution.
07-13-2018 09:38 AM
07-13-2018 08:53 AM
07-13-2018 09:02 AM
07-13-2018 09:38 AM
