Beginner
E1 conenction is showing Deactivated
HI
I need a help in E1 conenction is showing Deactivated.
Here is the scenario, where E1 conenction is connected to a pbx using Qsig.
The output are showing as below
Global ISDN Switchtype = primary-qsig
ISDN Serial2/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
    Layer 1 Status:
        DEACTIVATED
Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
#sh controller E1
E1 2/0 is up.
  Applique type is Channelized E1 - balanced
  Description: VOIP|Ericsson MD110|E1 ISDN|Y|||EQU-1-3-00|||V13|
  No alarms detected.
Any help is more appriciated.
venkat.
22 REPLIES 22
Rising star
Venkat,
you can follow this document to troubleshoot the T1/E1
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a754a.shtml
~ Suresh
//Suresh Please rate all the useful posts.
Beginner
Thanks Suresh, i followed the documents, but no luck, Even we check the cable connectivity its good,
Advisor
Hi Venkat,
Is your EPABX side configured for Master?
please check.
Can u  share the VG config ?
regds,
aman
Beginner
HI Aman,
Yest PBX side is configured as MASTER, i am sorry due to some restrictions i cannot paste all the configuration here.
Advisor
What is the router model u areusing and protocol [H.323/MGCP]?
if possible, please share controller and serial config.
regds,
aman
Beginner
version is Version 15.1(4)M1 - H.323.
sh controller E1
E1 2/0 is up.
  No alarms detected.
  alarm-trigger is not set
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Linestate Debounce is disabled
  Active xconns: 0
  Data in current interval (642 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 2 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     2 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     15397 Line Code Violations, 0 Path Code Violations,
     177 Slip Secs, 0 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins,
     177 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 2294 Unavail Secs
Serial2/0:15 is down, line protocol is down
  Hardware is VXB-2TE1+
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, crc 16, loopback not set
  Keepalive set (10 sec)
  Last input 00:13:20, output never, output hang never
  Last clearing of "show interface" counters 2d14h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     10 packets input, 50 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     10 packets output, 50 bytes, 0 underruns
Advisor
Can u try changing the CRC-4 to framing no-crc-4?
If possible, try changing from H.323 to MGCP?please refer the DOC.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/703946.pdf
regds,
aman
Highlighted
Beginner
Hi Aman,
Thanks for helping, yes i tried changing from CRC4 - no CRC4, however no luck.
I cannot change from H.323 to MGCP, there is no Cisco call manager. and router is in production can do that now.
Beginner
Well "Serial2/0:15 is down, line protocol is down" indicates that there's not even the Layer 1 working. So are you really sure the cables are working properly?
Do you have a loopback cable to test the interface card, so we're sure the card is working properly?
If there'd been CRC4 errors the E1 2/0 would be down too.
Beginner
Thanks Marc,
Yes i did the loopback cable test to on the interface card, here is the logs i took from voice gateway.
Jun 14 03:36:26.008 UTC: ISDN Se2/0:15 Q921: L2_EstablishDataLink: sending SABME
Jun 14 03:36:26.008 UTC: ISDN Se2/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Jun 14 03:36:26.008 UTC: ISDN Se2/0:15 Q921: User RX <- BAD FRAME(0x00017F)
Jun 14 03:36:27.008 UTC: ISDN Se2/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
Jun 14 03:36:27.008 UTC: ISDN Se2/0:15 Q921: User RX <- BAD FRAME(0x00017F)
Jun 14 03:36:28.004 UTC: ISDN Se2/0:15 Q931: L3_ShutDown: Shutting down ISDN Layer 3
Jun 14 03:36:28.004 UTC: ISDN Se2/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Advisor
Can u share the output of network-clock from router?
regds,
aman
Beginner
sh network-clocks
Priority 1 clock source: not configured
Priority 2 clock source: not configured
Priority 3 clock source: not configured
Priority 4 clock source: not configured
Priority 5 clock source: Local oscillator
Current clock source:Local oscillator, priority:5
Hall of Fame Master
You need to configure ISDN network side, thing for which you can search about.
Beginner
Hi Paolo,
i configured the controller as the isdn network side i didnt find any changes.
Content for Community-Ad
August's Community Spotlight Awards
