Community Helping Community
986
Highlighted
Hall of Fame Master
E1 conenction is showing Deactivated
isdn network side is configured under interface, not controller.
After which you have to shut/no shut.
Beginner
HI Paolo,
if i am not wrong, its already configured in the router.
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn overlap-receiving T302 7500
isdn incoming-voice voice
please let me know if it is wrong. thanks
Hall of Fame Master
You may have the PBX in loopback causing this.
Beginner
HI Paolo,
I configured the interface as isdn network side, still no luck.
Advisor
Hi Pavan,
Did u try configuring Clock on router?
Can u cross-check the parameters one by one u have configured on router with EPABX guy since after u change network on your side EPABX needs to be on Slave ?
regds,
aman
Advisor
Hi ,
The network -clock are missing.
I doubt this is problem .You need to configure network-clock participate
regds,
aman
Beginner
Hi Aman,
sure i will try this and will get back to you.
Advisor
it is slave configured
Global ISDN Switchtype = primary-qsig
ISDN Serial2/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-qsig
         **** Slave side configuration ****
regds,
aman
Content for Community-Ad
FusionCharts will render here
