10-10-2013 11:47 PM - edited 03-16-2019 07:50 PM
Hi All,
I've configured my E1 port on cucm but when i try to dial outside i got a dis order tone, when i contact the SP provider they told me that i've to register the head number they game to the e1. please guide me how can i do that ?
best regards
kennedy
Solved! Go to Solution.
10-11-2013 04:48 AM
what is A number ? and how do you configure it ?
10-11-2013 05:30 AM
Hi Kennedy
please follow the below:-
1- you need to reconfigure your VG as MR/Chrysostomos advise above , please take the above configuration which he already postes.There will be no configuration requred on yr GW.
2-On your CUCM , please go to your GW and check if your GW is registered .Please screen shot for the screenshot for your GW configuration on your CUCM.
3-Configure route group which will contain the registered Gateway.
4-Configure Route list which will include the configured RG on step 3.
5-Configure route pattern which will match your dialed number. use 9.XXXXXXXX as example and predot.
6-before dial any number check the below on your VG
show isdn status , sh ccm-manager
7- dial a call and test
thank you
please rate all useful information
10-11-2013 05:45 AM
10-11-2013 05:25 AM
He does need dial peers and to switch to h323, we do not support partial PRI with MGCP.
10-11-2013 05:49 AM
Jaime
Where is documented that
And why is not supported
I agree with you that h323 or sip is better but ....
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
10-11-2013 05:54 AM
chrysostomos1980 wrote:
Jaime
Documented in many places, just do a search.
10-11-2013 06:05 AM
Ok
Its not supported but it has a workaround about that
Agree with you also that h323 is the best solution here
set "enable status poll" parameter on the ccm. (cc gateway configuration)
2. on the ccm service parameter: change in advanced mode and fill out the "B-Channel Maintenance Status " field.
this could be:
S0/DS1-0@0123456789ABC = 0000 0000 0111 1111 1111 1111 1111 1111 (32 bits for E1 or 24 for T1).
0-means in Service
1-means out of Service
The signalling channels (15-E1 or 23-T1) are not affected.
10-11-2013 05:55 AM
@Java: You can still do it by putting your B Channel out of service and the current command it works with the new IOS. Not officially supported, but this is how it is accepted and heard it is now valid for different testing as well.
I dont think this is an issue with the Gateway. The gateway is sending the call out. The problem is with the calling number being sent out. The outbound call does not send called number and therefore the call would fail.
Can you please share the snapshot of Route Pattern which you are hitting. Also, can you run dial plan report for the number you are dialing.
10-11-2013 12:00 PM
Hi All,
Do i have to configure my E1 port for loop start or ground start on the MGCP gateway to be able to call to PSTN ?
best regards
Kennedy
10-11-2013 12:11 PM
Neither, E1 PRI is a TDM circuit. Loop start and ground start are specific to analog trunks such as FXO and FXS.
10-11-2013 12:28 PM
when i call from my cell phone to the office (E1) i can see that my number got reached at the gateway by debugging. so what did i do wrong ? is ther a special configuration for E1 to to call to pstn ? please help
