10-29-2015 03:26 PM - edited 03-17-2019 04:45 AM
I have ip phones registered with CUCM ver. 8.6 and Cisco router 2811(IOS 12.4.24T) regsitered as MGCP, this router have E1 PRI QSIG connected to avaya PBX.
the main scenario avaya phones will receive calls(company customers) then transfer it to cisco ip phones over E1 PRI QSIG, caller id of the caller(who calls avaya phone then transferred to Cisco phone) shown on cisco phones in case Cisco VG router registered as MGCP.
Incase the router resigetered as H323 or CME/SRST(in case of WAN failure) the caller ID as the previous scenario is not shown on Cisco phone, the voice gateway with cisco ip phones will be installed in remote branch and connected over WAN to CUCM 8.6 so, we need to solve caller id issue in case of WAN failure.
Can anybody help to solve caller id issue for voice gateway or CME/SRST with E1 PRI QSIG connected to Avaya PBX as the previous call scenario.
Thank
Taha
10-29-2015 05:19 PM
Hi Taha,
What digits are you seeing as the cli in SRST mode ?
What should you be seeing (same as CUCM) ?
Please give examples.
Can you also share ther config from your MGCP/SRST gateway.
Alex
10-30-2015 01:53 PM
Hi Alex,
Avaya agent calling number and after avaya agent transfer the call, avaya agent calling number still shown on cisco ip phone.
Incase of cisco router registered as MGCP, calling number of the originator shown on cisco ip phone(after ayava agent transfer the call)
Originator calling number(023338009) calls avaya agent(3220), this agent transfer the call to cisco ip phone 2701 over PRI E1 QSIG.
kindly find attached router configuration but not updated with CME/SRST configuration only contains MGCP configuration.
Taha
11-01-2015 12:16 AM
Note that Avaya PBX sends Caller ID in facility IE message through PRI E1.
11-06-2015 06:31 AM
Hi Taha,
Sorry for the long delay.
Could you have a look at this link re your qsid link to the Avaya.
http://www.cisco.com/c/en/us/td/docs/ios/dial/command/reference/dia-cr-book/dia_i2.html#wp1012311
In first instance you could try
int ser 0/1/1:15
isdn incoming ie redirecting-selection first
You may also need to look at
isdn incoming ie channel-id accept-qsig-variant
Your commands will be ignored when the mgcp is up but
should be effective in SRST mode.
Have a test
Alex
11-09-2015 04:07 AM
Hi Alex,
I tested with isdn incoming commands but i face the same issue, caller id of transferred calls doesn't appear.
Taha
11-09-2015 06:35 AM
Hi Taha,
Can you try adding the following.
voice service voip
qsig decode
supplementary-service h450.7
voice service pots
supplementary-service qsig call-forward
I am afraid I am stuck if this does not resolve the issue.
Have a look at this document re AVAYA to CME(That waht you are in fallback)
using E1 QSIG.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmetrans.html
Thesre are a few unsupported features - pleae read.
Alex
