06-02-2013 06:53 AM - edited 03-16-2019 05:39 PM
I have a E1 link and i want to distribute as follows:
Solved! Go to Solution.
06-02-2013 10:44 AM
Take a look at this to understand dial-peers (for IOS 12.4):
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/dialpeer/configuration/12-4/vd-12-4-book.html
About UCCX triggers and in general, use the available documents at CCO:
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/tsd_products_support_series_home.html
G.
06-02-2013 10:53 AM
I think for Hunt List u are saying Hunt group???
So what i am concluding is
I will create a Line group for the agents Extensions 1020-1040
I will add them to a Hunt list
I will create a hunt pilot 1001-1006, and i will select above hunt list in all hunt pilot.
Whenever a call hits to 1001-1006 it will hunt list to the line group.
Please correct me if i am wrong.
06-02-2013 11:00 AM
Oh boy.
Hunt Pilot -> Hunt List -> Line Group.
You only need one pilot for a Hunt List.
So for instance, Hunt Pilot 1001 -> Hunt List "HuntList1" -> Line Group "LineGroup1", containing 1020, 1021, 1022, 1023
Next, Hunt Pilot 1002 -> Hunt List "HuntList2" -> Line Group "LineGroup2", containing 1024, 1025
Next, Hunt Pilot 1003 -> Hunt List "HuntList3" -> Line Group "LineGroup3", containing 1026, 1027, 1028
And so on.
G.
06-02-2013 11:07 AM
Sorry Dear,
I appreciate your pateints for make me understand.
If suppose an ITSP routes a call to 1001 hunt pilot , In 1001 hunt pilot no agents Extension are available for ex: 1020,1021,1022,1023,they are not logged in the phone then the call will be dropped.
And the other hunt pilot agents may be sitting idel receiving less calls.
The link provided by you for UCCX is not opening.
Awaiting your reply.
Thanks for all your replies.
06-02-2013 12:29 PM
It is a Gr8 explaination by Mr. Szabo(+5). This scenario would be possible only when u advertise all DID numbers [which are mapped to a Pilot Number by E1 Service Provider, a pool of say 50-100 numbers ] to outside world or consumers.Pilot Number is in turn mapped to a Toll-Free number like 1800XXXXX .
In Contact center scenarios, only toll-free number[1800XXXXX] is made known to Consumers so that they call Contact center,Xlation pattern is created for Pilot Number in CUCM and a trigger is created in UCCX.
DID numbers are only used for receiving faxes.
regds,
aman
06-02-2013 12:44 PM
06-02-2013 03:43 PM
As Gergely and aman said, my understanding of flow(for cucm and uccx)
get the numbers using dialpeer--->cucm--->translation pattern (tollfreeno to triggerno)-->cti routepoint to uccx(same as trigger no)--->uccx(csq,agent etc)
Please rate if this helps
