577
kinwai
Beginner
e1 r2 configuration for thailand telco (true corp)
anyone have any sample?
it seems like they are using 2 different type of configuration for incoming and outgoing calls.
Got my outgoing call work by configured the following
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital dtmf dnis
If i used the same configuration for incoming, i got nothing. No calling and called number collected.
Got some hints from the telco, they provided sample configuration like
controller E1 0/0/0
framing no-crc4
clock source line
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country thailand
category 2
answer-signal group-b 1
caller-digits 4
and
controller E1 0/0/0
framing no-crc4
clock source line
cas-custom 1
country thailand
category 2
dnis-digits min 1 max 4
groupa-callerid-en
Both doesn't works.
Debug shows that it collected "3" , the number i was trying to reach was 35XX
Jun 19 16:13:10.455: htsp_process_event: [0/0/0:1(12), R2_Q421_IDLE, E_DSP_SIG_0000]
Jun 19 16:13:10.455: r2_q421_ic_seize(0/0/0:1(12)) Rx SEIZURE
Jun 19 16:13:10.459: r2_reg_start_digit_collection(0/0/0:1(12))
Jun 19 16:13:10.459: r2_q421_ic_seize(0/0/0:1(12)) Tx SEIZE ACK (with 100ms delay)vnm_dsp_set_sig_state:[R2 Q.421 0/0/0:1(12)] set signal state = 0x8vnm_dsp_set_sig_state:[R2 Q.421 0/0/0:1(12)] set signal state = 0xC
Jun 19 16:13:10.459: htsp_timer - 2000 msec
Jun 19 16:13:10.459: r2_reg_process_event: [0/0/0:1(12), R2_REG_IDLE, E_R2_REG_START_COLLECTION(93)]
Jun 19 16:13:10.459: r2_reg_start_collecting(0/0/0:1(12))
Jun 19 16:13:10.459: r2_reg_timer_stop(0/0/0:1(12))
Jun 19 16:13:10.459: htsp_process_event: [0/0/0:1(12), R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK]
Jun 19 16:13:10.459: r2_q421_ic_setup(0/0/0:1(12)) E_HTSP_SETUP_ACK
Jun 19 16:13:10.459: htsp_timer_stop
Jun 19 16:13:10.459: r2_reg_offhook(0/0/0:1(12))
Jun 19 16:13:10.459: r2_reg_process_event: [0/0/0:1(12), R2_REG_COLLECTING, E_R2_REG_OFFHOOK(94)]
Jun 19 16:13:10.459: r2_reg_ic_offhook(0/0/0:1(12))
Jun 19 16:13:10.459: R2 Incoming Voice(0/0): DSX (E1 0/0/0:11): STATE: R2_IN_IDLE R2 Got Event R2_START
Jun 19 16:13:10.671: htsp_digit_ready_up(0/0/0:1(12)): Rx digit='3'
Jun 19 16:13:10.671: R2 Incoming Voice(0/0): DSX (E1 0/0/0:11): STATE: R2_IN_COLLECT_DNIS R2 Got Event 3
Jun 19 16:13:10.671: r2_reg_generate_digits(0/0/0:1(12)): Tx digit '1'
Jun 19 16:13:10.767: htsp_digit_ready(0/0/0:1(12)): Rx digit='#'
Jun 19 16:13:10.767: R2 Incoming Voice(0/0): DSX (E1 0/0/0:11): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_OFF
Jun 19 16:13:10.767: r2_reg_generate_digits(0/0/0:1(12)): Tx digit '#'
Jun 19 16:13:13.671: R2 Incoming Voice(0/0): DSX (E1 0/0/0:11): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_TIMER
Jun 19 16:13:13.671: r2_reg_generate_digits(0/0/0:1(12)): Tx digit '3#'
Jun 19 16:13:20.671: htsp_dialing_done(0/0/0:1(12))
Jun 19 16:13:20.771: htsp_digit_ready_up(0/0/0:1(12)): Rx digit='5'
Jun 19 16:13:20.771: R2 Incoming Voice(0/0): DSX (E1 0/0/0:11): STATE: R2_IN_CATEGORY R2 Got Event 5
Jun 19 16:13:20.771: Enter r2_comp_category
Jun 19 16:13:20.771:  R2 Event : 5
Jun 19 16:13:20.771:  ####### collect_call_enable = 0
Jun 19 16:13:20.771: ######## Not Sending B7 ##################
Jun 19 16:13:20.771: r2_reg_event_proc(0/0/0:1(12)) ADDR_INFO_COLLECTED (DNIS=3, ANI=)
Jun 19 16:13:20.771: r2_reg_process_event: [0/0/0:1(12), R2_REG_COLLECTING, E_R2_REG_ADDR_COLLECTED(88)]
Jun 19 16:13:20.771: r2_reg_ic_addr_collected(0/0/0:1(12))htsp_switch_ind
Jun 19 16:13:20.771: //-1/85A096A48054/CCAPI/cc_api_display_ie_subfields:
it seems like it came in but too long later. anyone have any idea or have a sample config that works with this telco?
0 REPLIES 0
Content for Community-Ad
