01-13-2021 08:03 PM
We have a problem,when customer call out,the far end refused the call.If customer's phone didn't dropped,after about 40s,the phone would call out again.I checked the "Debug isdn q931" logs,the rx recieved disconnect message,but the phone cannot dropped.
Anyone see this issue before.
In sip VG
controller E1 0/0/0
framing NO-CRC4
line-termination 75-ohm
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
echo-cancel coverage 32
cptone CN
connection plar 4200
voice-port 0/0/1:15
cptone CN
dial-peer voice 911 pots
translation-profile outgoing Agentout
destination-pattern 91.T
direct-inward-dial
port 0/0/1:15
dial-peer voice 910 pots
direct-inward-dial
port 0/0/0:15
The log
Jan 13 02:47:17.719: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num
Jan 13 02:47:17.719: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x010D callID = 0xFDA6 switch = primary-net5 interface = User
Jan 13 02:47:17.719: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x010D
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Calling Party Number i = 0x0181, N/A
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '18300000001'
Jan 13 02:47:17.763: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x810D
Progress Ind i = 0x8288 - In-band info or appropriate now available
Jan 13 02:47:56.931: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x810D
Cause i = 0x8A9F - Normal, unspecified
Jan 13 02:47:56.935: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x010D
Jan 13 02:47:56.971: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x810D
Jan 13 02:47:56.975: ISDN Se0/0/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num
Jan 13 02:47:56.975: ISDN Se0/0/1:15 Q931: Sending SETUP callref = 0x0110 callID = 0xFDA9 switch = primary-net5 interface = User
Jan 13 02:47:56.975: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0110
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Jan 13 02:47:57.023: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8110
Someone can help me?
01-13-2021 11:57 PM
01-14-2021 12:13 AM
It's CUCM deployment,and the phone registered in the CUCM.
01-14-2021 12:59 AM
01-14-2021 01:08 AM
It's sip.The gateway is sip trunk to cucm.
01-18-2021 06:49 PM
when the gateway received the disconect ,it didn't send release messsages to cucm.
thankyou
01-18-2021 11:27 PM
