11-03-2010 05:49 AM - edited 03-16-2019 01:42 AM
Hi All,
I have a customer in Egypt moving to IPT. The local Telco can deliver one of the two modem types attached. Does anyone know what i would need to order for the voice gateway with respect to E1 connectivity to work with these type of modems. Which modem type will be the best to use ?
Dave
11-03-2010 06:17 AM
You need a VWIC E1 or VWIC2 card, and related DSP resources.
Either "modem" will work, but the 2nd has a better brand name.
11-03-2010 06:20 AM
Hi Paolo,
Does it use standard rj45 or rj48 connectivity ?
Is it configured the same way as a standard E1
Dave
11-03-2010 06:24 AM
Hi Paolo,
One more thing does the second modem give a presentaion of G703 and will i need a converter cable (Balon) or does it have rj45/48 connectivity.
Dave
11-03-2010 06:27 AM
Baluns are never needed with VWIC cards.
Just select the appropriate cable from the Cisco list, or in case of RJ45, do it yourself.
Note, both balanced and unbalanced interfaces are part of G.703 for 2Mbps.
11-03-2010 06:32 AM
Cheers Paolo. Let me get this clear the second modem type has the standard rj connectivity ?
11-03-2010 06:38 AM
I can only see what you see of the PDF, and any misinterpretation by my side could lead to mistakes that I do not want to cause.
Please remember to rate useful posts clicking on the stars below.
