E1 Sip trunk Best Practices
Juraj Papic
Level 3
Level 3
Hi all,
I have my gateway with only two (2) interfaces and one E1 port. One interface is used to connect to the network, now I have to add two(2) more E1 sip to my gateway. For this type of topology, what will the best practices be to add connect the E1 sips?
Thanks.
TONY SMITH
Can you clarify what you mean by "E1 SIP"?   E1 is a two meg bearer, which could be a phone line (commonly ISDN) or could be a data circuit.  Where does SIP fit into your design?
