07-21-2011 12:29 PM - edited 03-16-2019 06:04 AM
i have 2611 H.323 E1 router (outgoing and incoming working fine), once i replaced to 2811 E1 Router with the same configuration with same Dial-peer but i couldn't access outgoing for all phones but E1 Status is UP,
my question is why i coudnt access outgoing althought the E1 status is up and i put the same configuration manually also ? , but still i have the same problem
i am thinking that i need to upgrade the router 2811 to higher image althought the router it is new from cisco ???
it is alright ???
please updates me soon
thanks
07-21-2011 12:33 PM
Woudl you pelase collect the following:
sh isdn status
sh run
debug isdn q931
debug voip ccapi inout
07-21-2011 12:35 PM
thanks for your response
now only i have show run
E1-Voice-Gateway#sh run
Building configuration...
Current configuration : 2257 bytes
version 12.3
hostname E1-Voice-Gateway
boot-start-marker
boot-end-marker
enable secret 5 $1$mcfL$.KTIrHj7WoXkqbSkheq/Z/
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
no aaa new-model
ip subnet-zero
ip cef
ip host CCM-A 192.168.50.254
ip host CCM-B 192.168.50.253
ip name-server 192.168.50.254
isdn switch-type primary-net5
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet0/0
description Connection to IPTEL Network
ip address 192.168.50.241 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn T309-enable
isdn T203 30000
isdn T310 60000
isdn bchan-number-order ascending
no cdp enable
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.50.1
voice-port 1/0:15
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
dial-peer voice 1 pots
incoming called-number .T
destination-pattern .T
progress_ind progress enable 8
direct-inward-dial
port 1/0:15
dial-peer voice 3 voip
preference 1
answer-address 6[1-2][0-9][0-9]
destination-pattern 6[1-2][0-9][0-9]
voice-class codec 1
session target ipv4:192.168.50.253
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 voip
preference 2
voice-class codec 1
session target ipv4:192.168.50.254
no vad
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
07-21-2011 02:17 PM
you have these
you need to add network clock participate , and you may need also network clock select
07-23-2011 11:00 AM
thanks for your supporting
i think that i send to you the old configuration or not current configuration in the router , i will update u tomorrow
my question if these commands are added how the E1 is up ???!!!
thanks and regards
07-23-2011 04:14 PM
Hard to answer because "UP" can mean many things. Up at layer 1? Layer 2? or Layer 3?
What do you get when you execute the command SHOW ISDN STATUS? Does it say multiframe established? If not, then it isn't "up".
If it does, and you can't make calls, then you likely have the isdn switch emulation type set incorrectly, framing incorrect, line coding incorrect, or something like that. But if you're just looking at a green light on the card, all that means is that it sees power/sync from the telco....it doesn't mean it's necessarily "up".
07-25-2011 04:50 AM
thanks u for your supporting
in actually it is solved , the solution is
adding
# Network-clock-select 1 e1 0 0
thanks and rgards
07-25-2011 06:53 AM
Good to have it solved
so mark the Discusiion as answered
