e164 CUCM/CUC
I have this situation.
My DN are using E164 format example:
551121263608
Enterprise Alternate Number is 3608 for internal calls with 4 digit extension
At CUC the extension of the voice mail is with 4 digit, if put the E164 at the extension of unity the call i go to the default greeting of CUC.
How can i accomplish this?
I need that when the forward calls go to the CUC, go to the user greeting and the MWI works.
Leonardo Santana
*** Rate All Helpful Responses***
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
I would convert the extensions in Unity to be E164, and then add the 5 digit as alternate extension.
The reason it might not have worked when you tried it might be that your voicemail profile is not properly adjusting the number, you should leave the VM mask as either blank or 12-Xs as that appears to be your DN lenght.
5 Replies 5
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Configure alternate extensions in CUC
java
if this helps, please rate
Maren Mahoney
VIP Advocate VIP Advocate
VIP Advocate
You can use a mask at the Voicemail Profile to mask just the last four digits for calls forwarded to CUC.
As Jaime suggested, it is a good idea to have the E164 number set as an alternate extension as well.
Chris Deren
Hall of Fame Master
The voicemail mask solve my issue.
Thanks a lot.
Leonardo Santana
Leonardo Santana
Kita
Beginner
Beginner
Alternate extensions in Unity are probably your best bet
You can accomplish this with a BAT file with the following fields:
Alias,Extension,Extension_Alt1,Extension_Alt1_Partition
1. CUC BAT export of users
2. Create BAT/CSV file using the headers above
3. CUC BAT modify users with the new CSV file
Recognize Your Peers
