E164 dialling to internal number
kpintens
Hi all
is there a way, without using transformation patterns to translate an incoming E.164 number to 4 digit internal number
eg +32 1456 789 3123 to 2501
currently it is working using a transformation pattern on the trunk but using this method as soon as we partition the numbering plan incoming calls fail.  The internal numbers are in <none>
Thanks in advance
Koen
Please remove the significant digit and configure xlation pattern to match the full pattern eg
Translation-pattern \+3214567893123
partition : select a partition that your sip trunk CSS has access to
CSS: Select a CSS that has access to the phone DN partition
called party transform mask: 2501
Ensure your sip trunk CSS can access the pt of the xlation pattern
Please rate all useful posts
11 Replies 11
Transformation pattern are used to change the number displayed on the phone once the call arrives.
I'm assuming that 2501 is an internal number, you can to this in the gateway or the trunk configuration page.
Call Routing Information - Inbound Calls:
thank you
that works but then it doesn't work when adding partitions
so in a way the problem lies now with partitions and CSS.... grrr
For example:
Parition:
PT-Phones
Since the phones are now in a partition the GW cannot reach the phones without a CSS that contains the above PT:
CSS:
CSS-Gateway: ---> PT-Phones
If you assign this CSS to the GW then calls will work.
en calls will work
Significant Digits: 4
Calling Search Space: CSS-Gateway
this is what I have
PT_site -> phones
PT_system -> route patterns
PT_site_emergency -> specific emergency translation for that site
CSS_Site has all three PT's
as soon as I assign a phone in the PT_site the incoming calls fails, provider msg that there is no phone allocated
Ok,
Are you trying to translate 32 1456 789 3123 to 2501 --> if this is the case use the GW to translate the number to 2501
or
32 1456 789 2501 to 2501 ---> use the CUCM as shown above.
Go the Dialed Number Analyzer in Serviceability page, once there select:
Analysis -- > Gateway
Select on the Gateway
Calling Party: (Any number)
Called Party: 32 1456 789 2501
Any attached the output
here is the catch..... it is a SIP trunk directly on the CUCM no gateway involved, no CUBE due to budget restrains
This is very straight forward. You should use translation patterns not transformation pattern for this. Configure the pattern and select the CSS_site for the xlation pattern.
it doesn't work :(
trunk significant digits 6
translation pattern 123456 to 2000, PT_site, CSS_site
I am sure I am must be overlooking something
that worked
thank you all for the help
Glad to help. please mark the thread as answered
