E164 Pattern Map
farbod.karami
Beginner
Beginner
If I have a certain number range (say) "98[1-8]..$" and I wanted to send that to the CUCM server at 10.1.1.1 but then I had a call (say) "87[1-9]..$" which I wanted to send to "10.2.1.1" using CUBE using e164-pattern-map, how would I create the config file to also include the destination, so that I wouldn't have to include that in the router config under dial-peer as "session target ipv4:x.x.x.x" and can manage it from the config file directly?
Marcelo Morais
VIP Advisor VIP Advisor
VIP Advisor
Hi farbod.karami,
 the e164-pattern-map is a list of "destinations-pattern" not "session target".
 In other words, you can not add a "session target" to it.
 For more info, check this link.
Hope this helps.
Hi Farbod
Your question isn't clear - what is the 'config file' that you want to put this in?
You have two types of maps in IOS that you might be confusing:
e164 maps: allow mapping multiple destination-patterns to each dial peer
server groups: allow mapping multiple session-targets to a dial peer
It may be the server groups feature you are looking for (http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/xe-3s/vd-xe-3s-book/multiple-server-groups.html)
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Recognize Your Peers
